Beginner question on removing mill scale
racerboy
New Jersey
I’m new to welding and was planning on doing some work with 1/8” mild steel. I know you are supposed to remove the mill scale to get clean metal. I saw a YouTube video that said to soak it in vinegar. I tried that, and it definitely removed the top layer, but should I also grind it more so it is shiny?
This photo shows the difference after soaking in vinegar overnight (bottom piece).
txvwnut
Bedford, Texas
I remove mill scale with a flap wheel. Depending the weld process you are going to use any leftover residue from the vinegar soak might cause an issue.
WillyBoy
Genesee valley area of New York state
I've had good results using a knotted wire wheel in an angle grinder. Easy to run along the area where the bead will go. Just watch where it's going. Trying to remove a shop rag that it sucked up resulted in some bad language. Fortunately it wasn't my shirt.
jmdirk
Never really tried a chemical process. Removing it mechanically is usually faster. Flap wheel, sanding disc, stripping discs, wire wheels all work fairly well.
Jswain
Calgary, AB
Use either resin fiber discs, flap discs, or grinding wheels to remove the mill scale prior to welding out. Both sides of the material, 1/2" or so around the area you are welding. I mostly find wire wheels just polish it, leaving it on there, unless the metal is slightly rusted as well
bwringer
Indianapolis
Jason at Fireball tool did a video on this testing different methods and consumables not too long ago.
Poke around on YouTube and you'll find it. I'm not in a position to post a link or embed at the moment.
danielbuck
it's almost always best to get down to bare metal when welding. If the steel isn't shiny looking after whatever method you used to remove the mill scale, a quick hit with a flap or strip disc along the area you'll be welding to right before welding will get any remaining residue off of the metal.
That said, it'll probably weld just fine straight out of the vinegar. I've welded through mill scale before for quick setups (to temporarily brace something while it's being built), it'll weld.
MoonRise
IMHO, a wire wheel/disk/cup (even a knotted one) is NOT going to reliably and completely remove mill scale.
Red rust, yes.
Black/gray mill scale, nope.
Grinding wheel or flap disk is my usual go-to for mill scale removal. Or media blasting (if the part can fit in the blast cabinet or you are using an 'external' media blaster set up).
Some welding processes can tolerate a certain amount of mill scale or 'crud' and still produce acceptable results. But best welding results are always achieved if you have clean bright shiny metal to start with.
Acid (vinegar is an acid) can remove rust and mill scale on steel, but depending on the specific steel alloy can cause material problems later (corrosion of the steel or hydrogen embrittlement in 'hard' or 'high strength' steels).
garboui
Southern Ontario
I have been looking for less grindy ways for this for a while. Vinegar works but often needs a long soak to get through. Other steel in the area will also rust from the open bath vinegar. Muriatic (HCl) is often at concentrations that work fast but are hazardous to handle and creates too many safety tradeoff IMO. This year I started using acidic toilet bowl clear. This stuff is usually ~10% HCl and is on the much safer side of acid concentrations. Being a "gel" it does stick around where you put it or can be brushed back in place. Oh, it smells nice too! Depending on teh thickness of scale, ive had it down to bare metal anywhere from 15min to 1h.
danielbuck
I wonder if citric acid would work? I use citric acid to remove zinc coatings and also rust, it seems to work way faster than Vinegar does. I like it because it's so safe, don't need gloves and can dump down the drain
scooby074
Nova Scotia
For most of the welding we do (ie: non code, simple repairs/fab) grinding off millscale to bare metal really isnt required IMHO. If I do have to, I usually use 3m grinding discs or the Walter wheel made for removing scale. I try to avoid as much grinding as possible.
garboui
Southern Ontario
If it removes zinc and rust, seems similar enough to HCL that it would also be effective to remove mill scale. Worth the experiment. For science of course!
Crazyjake8493
Upstate NY
I've always used a flap disc or stripping disc on an angle grinder to remove mill scale. I wouldn't even consider chemicals unless it was a place I couldn't reach with a tool, and if it comes to that I'm probably not good enough to be welding that spot anyway.
danielbuck
if you had a large plate, chemical would probably be alot easier and way less effort. Small pieces, grinder is way quicker.
BigMike782
My experience has been it depends.....
I have used hard grinding wheels, flap discs, wire wheels and a needle scaler.
When I built my welding table the scale was so heavy and thick that the only thing that would take it off was a needle scaler.
Jswain
Calgary, AB
Yep. This.
These are my go-to for mill scale. Contrary to what you might think, they're quicker than a flap disc too.
I just assumed he was talking about the purple or black stripping discs, I didn't know those worked good for mill scale. Good to know
I like the thought of using them as they probably wouldn't gum up like a flap disc or resin fibre
All
Good Grinder Almighty!
That is quite the collection of already chucked up grinders at the ready.
There is some experience evident in that photo.
Avadon
Mill scale, rust, paint this does it quick, and does not remove the steel itself.IMG_5888.jpeg
For real, these are wayyyy better than flap wheels. They don't remove material unless you really go to down. They're great for paint, mill scale, rust. I stopped using flap wheels, too expensive and don't do a great job at hard mill scale. You can even get these paint stripping wheels in packs off of amazon for cheap.
b-dog
Lakewood, CO
SM Racing
Huntsville, AL
I tend to use a combination of techniques. Grind it, either with a flap wheel, rock, or small 90 die grinder. Heavy scale tends to clog those. If I am working with plate or short segments of tube, I have an acid tank outside that uses muriatic acid mixed 7:1. I can drop the parts in the tank and go deal with something else.
Option 3 is sand blasting in my cabinet and that's usually my go to. It leaves a nice finish to piant, cleans up all mill scale, rust corrosion, etc.
BD1
north side
I like the Eastwood CST contour tool. It does a great job and they have 1'' wide wheels plus a variety of the 4'' ones. It is great for cleaning the welding table top too. Amazon has them and so does Harbor Freight.
