Bell system
doc tuolumne
sonora, ca
have a pair of B/S pliers...blunt tip needle type, has a flat grip at tip with a step and tapered gap towards the rear, for stripping solid analog phone wire, also a B/S Ingot of soldering alloy, all gotten from my uncle, worked for them from post Korea to just pre electronics, late 70s....
davethorik
Norka, Ohio
I only have this one Bell System tool, a heavy duty Stanley 7/16 tip flathead screwdriver with conical bolster. Marked "BELL SYSTEM E"
I checked the plier drawer in my toolbox at our summer home and found these Klein lineman’s pliers. I can’t decipher the date code but it’s something after 1950.
-DonA3D7421E-23A6-4FB9-9890-A4338BC854F8.jpg99CE75D9-DBCA-4822-A5AF-BB3CD65C57C4.jpgEFBE3324-41B3-4761-A010-0847038DFDF7.jpg9D7052CD-B15A-4F50-9143-B949F4E26163.jpg3C5F2504-FF87-4B5B-9CC7-A039C9987015.jpg
I picked this up today at the flea market because I suspected it was a Signal Corps lineman's tool pouch with provisions for hanging off a belt. It's heavy duck, as you can see, OD green in color, and has what I thought were three letters of what I suspected to be a partial mfgr's marking reading, "HEL", as in SHELTON, or something like that.
Much to my surprise, I was right about it being a lineman's pouch, but wrong about the application! It's not "HEL" but "BEL", as in BELL SYSTEM. After closer examination, I can see a faint "SY" as well. Pic 2 doesn't do it justice (I will try to re-take some photos at a different angle in different light).
Oh, I am 100% sure it's Bell System, Jeff. What kind of parts? I didn't provide any size context, but it's about 10 inches deep and the diameter of the opening, which has a steel reinforcing ring sewn in it to help it keep its shape, is 6". There is a also a pocket inside. And those two straps you can see with clips for hanging it off a belt or anything else I suppose. Does that sound like a parts bag?
You can see how I may have mistook it for Signal Corps though, right? Canvas. OD green. Web straps. (C'mon, bail me out here... :lol:)
Something about this story seems very familiar to me. You shouldn’t feel alone! We are drawn to Olive Drab like moths to a flame.
jeffmoss26
Cleveland, Ohio
the bag would go on a tool belt to hold phone jacks, parts, trash...anything really. I have a couple of them in the collection.
Username already in use
I stumbled across this Bell System brass padlock (with key) at the flea today. Someone cut off the shackle, but the lock still works fine.
I picked up an antique cable puller today at the flea market. While this is not a "Bell System" tool, per se, in terms of markings, Western Electric was a division of Bell and operated as its equipment supplier. The marking is worn. I've included a naked close-up and a chalked close-up, but you really need a magnifying glass to read it. It's marked BUFFALO GRIP NO. 1, in a circle, and FROM / WESTERN ELECTRIC CO. / NEW YORK CHICAGO / PAT'D APR. 25, 1893 / CANADA 1898.
All of the examples I have seen on-line of this tool are newer, with the same model number (No. 1) or an even newer "No. 2", all a Nov. 29, 1910 US patent date, and a Canada 1911 patent date.
I'm stumped on the patent number itself. I can't find it anywhere on-line (DATAMP, Justia, Google Patents, etc) using the date. That is a valid patent date, but I haven't located the actual patent yet.
EDIT: Also, does anyone know anything about the "X"? What does it signify? (It almost looks like the crossed cannons of the Ordnance Dept.)
Here’s one based off a standard Williams ratchet, but they modified it for Bell.
Stamped SPECIAL.
# KS-8237 insulator wrench
According to the document, it’s supposed to have what appears to be a 5/16” female hex drive with 2 male hex drive sockets of different lengths.
The hole in the handle is original. Tether maybe?
Jeff, can you or anyone else point out the style of insulator or how they were mounted with hardware?
doc. off the web:
rickhigginshtbr
Lower Bucks, PA
I have that same one Paul, but not nearly in as nice of shape!
My oldest used a yankee the other day, he was amazed when I told him it was Oder than his grandpa!
I was lucky enough to pick up this vintage Bell System tie clasp at the triple early bird flea market this morning. I'm pretty stoked about it, frankly. Gonna wear it the next chance I get. Everybody always tells me how horribly out of fashion my neckties are. This will really cement my reputation! HAHA!
EDIT: Added a photo not reflecting sun to show more detail.
LesserSon
PA USA
Oh, ho! That is a nifty find, Lugz - two tie bars in one day.
I guess I should post a photo of something...
The little pliers are Utica-made. The screwdriver I found with the leather washers mostly gone and the dowel broken, so I trimmed the end off and put some stain on the handle. It was an early project, and I would work harder to restore it if I did it today.
Stuart in MN
Minneapolis
Someone should start a thread about mechanically themed tie clips... :) I have a few interesting ones including a forklift, a jet engine, a pair of pliers, a meat cleaver, and a little mechanical pencil that actually works with lead in it.
Catfishdan
Central coast, California
Found a bell systems screw driver today. It's in bad shape, but it's marked Stanley and bell systems so I ponied up the quarter just to post it here.
LesserSon
PA USA
Geez, Dan, that doesn’t look too bad to me - is that just white paint? I plucked these Utica-made S-259-8 pliers Saturday. I don’t think Utica typically date-stamped pliers, but the “4-55” inside the grips looks a lot like Apr1955, unless it could be a Bell System part number.
I picked up this BELL SYSTEM Millers Falls No. 1100 adjustable hacksaw frame at the flea market this morning. I like the pressed steel pistol grip. Slides in and out and that little thumbnut locks it in place.
