Bench Bleeding Master Cylinder, Vacuum Pump vs Pushrod
peejay75
Seems that using a vacuum bleeder uses (wastes) fluid into the collection cup, versus using the pushrod/pedal method that recirculates the fluid within the reservoir.
Any advantage to one method over the other?
gahrajmahal
Cincinnati, Ohio
No matter how you bleed your master cylinder bleeding the rest of the system is where you will have issues. My Honda Ridgeline could not get a high and firm pedal until I bought a Motive Power pressure bleeder. Here is my thread on this miracle tool.
Bigblue&Goldie
I actually just realized I'll likely be doing another master cylinder (all new booster/master/soft lines/calipers/rear drum cylinders) next week. I'm finishing off putting F-350 brakes on a Bronco after an axle swap. I won't be driving it any time soon though. My plan is to bench bleed the master with the syringe, get it installed and flush the existing hard lines of old fluid. I'll then get all the new brake components in place, and use my Speedi Bleeder to do an initial bleed. Once I get the truck running I'll re-bleed the system. My main priority is getting it all in place without running the old, dirty fluid through the new parts.
P
peejay75
Well, just attempted to "bench" bleed the master attached to the firewall...seems that way definitely wastes a lot of fluid unnecessarily. Next time I'll try doing it via the pedal, and using a camera to record for bubbles...(helper is unreliable at the moment)
anyhoo, after all that work, the master wasn't the problem, who knew? (me!) on to bleeding the damper next, while waiting on the slave cylinder to arrive.
(i did try using the mityvac to force fluid through the opening in the reservoir before bench bleeding, but it's not centered in there, and getting a syringe in there could be tricky, i.e. frustrating/cuss-inducing!)
Bigblue&Goldie
The problem with bench bleeding on the vehicle is the master is usually mounted at an upward angle, which traps air at the end of the bore past the furthest port. Try taking it off and bleeding it level in a vise.
gungatim
west mich
Bench bleeding literally means bleeding it on the bench before it is installed.
Bigblue&Goldie
I get that, read the post I'm responding to. A lot of people, o.p. included, use "bench bleed" synonymously with the initial bleeding of the master cylinder prior to bleeding as part of the system.
