shamrock12
Just curious why it seems to me that 8" bench grinder is a popular choice? From what I understand, the ideal speed is approximately 5000 to 5500 "linear" feet per minute. Many of them are available with 1800 and 3600 RPM motors. At 3600 RPM, the 8" grinding stone would be spinning at 7540 FPM (86 MPH) which is pretty high but only at 3770 FPM with 1800 RPM motor. If the grinder stone is spinning too slow, it does not cleans well and loads up. If it is spinning too fast, there are two dangers: you risk the chance of burning up (overheating) the tool you are sharpening, but that can be controlled if you know what you are doing. The other danger is an increased chance of grinding stone disintegrating and potentially cause injury to the operator.
So therefore, a 6" grinder with 3600 RPM motor is perfect and so is a 12" grinder with 1800 RPM motor. A 10" grinder with 1800 RPM will be a bit slow (4710 FPM) but still is a good speed.
