curliejones
- Joined
- Aug 19, 2013
- Messages
- 34
A two/three part ??
I've read about one technique for sharpening shop tools where the guy recommended starting and stopping his bench grinder to sharpen chisels, etc. It lets him use his single speed grinder and catch the steel at diminishing speeds. I don't do a lot of sharpening and I wonder if this start and stop technique is hard on a good motor or just puts wear on the on-off switch?
If indeed it is not that bad for the motor, could / should a momentary foot switch be used and leave the grinder switch in the "on" position? As long as the amp rating is high enough for the switch, would a Big Foot switch for trolling motors work OK? A 15A rating on a switch and a grinder that is rated at 5A , for example?
