bench grinder wheels
lodestar
Montana
I'm sure there has been plenty discussion on here about this and I searched the forum ( Bench grinder wheels ) and the search returns threads that have no relevance. I rarely have any luck using the search on here. ?? Maybe I'm missing something.
Anyway, I need 6" bench grinder wheels and am looking for advice on Brands and where to buy. Thanks
rlitman
Long Island
I get mine at my local Ace Hardware. Sears used to carry them too IIRC.
I know that Home Depot does not.
Remember, always perform a ring test on a new wheel.
MFolks
Springfield Mo.
Striking it lightly with a hammer to see if it's intact,a dull sound indicates a crack,or a void,not to be used.
MushCreek
Upstate South Carolina
Wheels come in different grits and bonds for a reason. 'Fine' is OK for finish work, but if you're trying to rough down a chipped chisel, you'll be there all day, or turn it blue and ruin the temper. To be honest, most bench grinder wheels seem to be pretty similar, regardless of brand. In my trade, we use a wide variety of grits and bonds, but that's on a surface grinder, doing precision finish work. Many of those wheels are inappropriate on a bench grinder (too hard, too soft, too fine, etc.) Ideally, you want a coarse/medium wheel on one side; fine on the other, and keep them clean and trued.
When I have a LOT of material to remove, such as putting a big radius on the corner of a piece of steel, I like a 6" belt sander with a coarse belt.
As for brands, a name brand like Norton will be great, but expensive. I have a Harbor Freight 8" bench grinder, and the wheels that came on it are very soft. Good for keeping the part cool, but they wear down fast. Places like MSC will have a wide variety of wheels to choose from.
BillK
Beautiful Southern Maryland
I have tried "less expensive" brands of abrasives on several tools in the past and learned my lesson. You get what you pay for. I stick with Norton for grinding wheels and sanding belts. 3M for my cut off wheels. etc.
el monte slim
Midwest USA
When it comes to bench grinders and buffer motors, I believe it pays to use quality name brand abrasive and finishing products. (As BillK said above, you'll avoid disappointment by using Norton and 3M brands)
For maximum flexibility of use in my workspace, I have Norton aluminum oxide coarse/medium and fine grinding wheels installed on my bench grinder. I have a DeWalt wire wheel, and a 3M Scotch-Brite EXL deburring and finishing wheel mounted on the buffer motor. It should go without saying here, but protective eyewear is a must at all times when using these tools.
For sourcing these products, I would recommend a reputable industrial distributor, rather than a hardware store or home improvement center.
Augus7us
Central Ohio
I use norton on my surface grinder, they are some of the best from what my research found.
There is a bunch of info on wheels on practicalmachinist. You can search either site on google by typing the following without the []'s.
[search terms site:www.whateversite.com]
