Bench grinders. Decision time
sqznby
Coastal NC
So when I'm in search for a grinder to hopefully mount the MultiTool on does it matter what size the wheels the grinder takes as in a grinder that takes a 6inch wheel . Does the MultiTool mount to any of those size grinders 8or 6 inch
I'm I making sense ?
Thanks
scarrylarry
I believe they are adaptable to both but, you will benefit more from the 8" from the more powerful motor over the 6".
lis2323
I agree. If you can afford it go for the 8". Usually (debatably) rated at 3/4 HP.
Also consider a QUALITY used machine as opposed to brand new lesser quality. All mine are Baldor powered so I'm kinda partial to them.
LARRY: Not certain where, but I'm certain Jet products are available in BC.
exmaxima1
Midwest
Thanks
scarrylarry
Now I understand. The wheel size doesn't matter but you need:
--3450 rpm for the MT adapter. It uses a drive wheel a bit under 6", and you need 3450 rpm for adequate surface speed.
--A grinder that employs wheel guards that bolt on (not clamped). The adapter uses the guard bolt holes to mount to.
--At least 1/2hp (honest power rating), and more is better. I'd look for at least 5 amps of current to really appreciate the MT belt adapter.
scarrylarry
West Coast of Canada
Thank You !
scarrylarry
scarrylarry
Hello lis2323
It seems that Jet Tools and Jet are two different companies . Yes Jet is readily available in B.C. at Lordco for example and KMS tools . But Jet Tools who carries the Multi Tool Belt Grinder attachment I think is only available in the USA .
Not sure if I went across the line and purchased the MT attachment I would be able to bring it back duty free .
lis2323
Hello lis2323
It appears the MTBG can be purchased easily on line through Amazon, Trick Tools and others. No duty bringing it into Canada but Border Services will ding you the PST/GST (12%) when it crosses the border into BC.
