Bench testing a GM radio in the shop?
Jimi
Maryland
I've got a radio in a GMC Acadia I want to hook up for bench testing. (AM/FM/CD/Satellite/Aux)
Does anyone know of something called a bit controller that I'll need to do so? Possibly a sat antenna too? Wondering if this will actually work outside the car.
TuxThePenguin
What model radio specifically? Some stock radios need a data bus connection (CAN bus or whatever that particular car uses) and some are functional or partially functional without. I imagine a lot are probably at least partially functional w/o a data connection since they are often bought from third parties (like Harman International, Fujitsu Ten, etc) and the "core design" of the radio may not require the data connection to operate.
I personally probably won't know the answer for the model you have, but it'll probably help someone.
"Bit controller" doesn't sound like a specific part to me. Sounds just like someone saying you need a data connection to a controller. Digital signals are transmitted using bits so I imagine someone you got advice from happens to call that a "bit controller."
rquackenbush
Raleigh, NC
It should work outside the car... I think what you're referring to might be the CANBUS interface. When I upgraded the radio in my Jeep Wrangler JK, I had to get an interface to keep the steering wheel controls integration.
Thinking about it more, your scenario is the opposite of mine. You're taking the radio out (instead of putting one in). And really, that radio might be a full infotainment system. It probably expects the car CANBUS to be there for certain features (e.g. setting the current time). I don't know how it will act without that network available.
What year car/radio are you working with?
pi_guy
N/A
Don't think so the radio has to be registered to the car When I changed my 2011 Suburban media setup screen was damaged, had to go to dealer to run program to configure. From what I understand it involves contacting Detroit.
mc4life27
Depending on what year the radio is will allow me to let you know for sure but I know that I’m 99% sure you have a date turn in and it may even have a date turn for the amp. So not really able to use it as a bench radio unless you have a date bus interface that gives the date output to turn on the radio. If it has the digital Bose amp then you need the amp to make the sound work too.
Wrench97
Southeastern Pa
Anti theft, in the early 2000's GM started making the radio an integral part of the car, the data link turns it on and off and checks if the vin number matches, if not it needs to be reprogrammed to match the vin on the GM site. For sure if the car has onstar you can't use it on the bench.
