Bench top lath/ drill press milling machine
Ripped
Last night I was trying to mill some brackets on my drill press with moderate success.
I am thinking of getting a benchtop combination drill-press, lathe milling machine
Do you guys have any recommendations?
Thanks
E.Marquez
Kempner Texas
Ive had a Smith Midas 1220 XLT for several years now.
If miling steel is your plan, skip all but the most robust 3:1 machines, the Smithy Granite in example. . and even then its going to be slow going, but very doable.
I CAN mill steel on my Smithy 1220XLT, but its not very fun or productive.
It does well on Al, brass and other softer materials, but I leave steel for the lathe or drilling functions. Which it does very well at in respect to its capabilities.
zmotorsports
Northern Utah
I agree with above.
I had the larger Smithy, the 1239 and it was a much better lathe than milling machine. On aluminum it was ok but not steller, steel not worth the headache at times.
As for task specific benchtop milling machines, check out Precision Mathews. Matt has a PM727 or the larger PM932 that are nice machines. My son just built up a CNC version of the PM932 and it seems quite solid and cuts well for what it is. Matt is also great to deal with, excellent customer service.
HanShotFirst
NW Nevada
The small knee mill from Harbor Freight is a downright decent hobby mill. You're better off buying a mill, and then picking up a lathe later on. The 3 in one machines are rather annoying to work with.
Ign
Butte Peak ND
This. I'd sooner have a bench top mill than a 3-in-1
And don't mill on a DP, the bearings are not intended for those loads.
Glassdave
i keep leaning toward getting a multi purpose CnC machine for my shop and have been looking hard at the Shopmaster Mill/Turn. The company has been around since i can remember and it looks like a decent (non professional) machine. Anyone has experience with this one while were on the subject?
https://www.shopmasterusa.com/
Stuey
28m above sea level
If you decide to go with separate equipment, Little Machine Shop's configured Seig-made equipment seems to be a step above others brands' Seig-made tools. Their benchtop mill is on my wishlist, and their lathe too if I ever outgrow my Sherline.
txvwnut
Bedford, Texas
DON'T JUST DON'T! No customer service, the machines are worse built than some of the Harbor Freight ****. These are the cheapest of the cheap Chinese **** out there. Yes they say made in America but all of the casting is done overseas and all of the parts come from overseas suppliers too.
I owned a Smithy before I got a shopmaster built machine and I wish I had never sold the Smithy.
Glassdave
thanks, glad i brought it up. I was aware they were imports (what isnt these days) but did not know they were so bad. Also like a lot of things these days they sink more into marketing then the actual product . . . . thanks, i'm guessing thats gonna save me a headache.
jonesg
northern Maine/
I stared with sherline. Went bigger with south bend 9" model A with threading capability.
Ended up selling the SB and sticking with sherline with its greater accuracy. I just made bronze axle bushings for my old snowblower with it, it's a nice hobby size machine.
CNC is perfect for high volume production runs, for one or two off custom work it's not worth the expense, anyone can work to high degrees of accuracy with manual machines, hand fitting everything. I can mill free machining steel, brass, bronze. Alum ,nylon no problem.
jonesg
northern Maine/
Using a 90 degree adapter plate you can mill on a lathe. You cannot lathe on a mill.
Most machinists said start with a lathe, get a mill later.
My Old Tools
Hamrick Lake, TX
If you don't want to spend the time tracking down a good older US machine, at least step up to a Grizzly. They seem to be doing a bit better than the average Chinese **** these days, and they have some parts service.
manwithtools
Lebanon, TN
As has been said before, the three in one machines are an entry into the machining world with limitations. If you think you might want to do more than simple items, I'd suggest seperate machines or buy the 3n1 with wide open eyes about future upgrade paths.
Tooling, gauging and misc items will cost as much if not more than the simplest machines. You can upgrade over time, but you need to consider the tooling expandability. If you start with a MT2 machine and want to move to a larger machine, you may have to replace much of what you already bought for the smaller machine.
The main problem I see with 3n1's is setup conflicts and working envelope limitations. It's a slippery slope, enjoy.
If forced to make decision, I'd start with a mill and get a lathe second, highly project dependant, so your choice might vary.
BukitCase
Oregon
"You cannot lathe on a mill."
Yeah, you (sorta) can :D (necessity is a MOTHER:sad:)
If you're gonna mill steel, I'd go for a square column mill if you can't find a decent Bridgeport - mine's a Grizz G0755... Steve
davethorik
Norka, Ohio
Ive seen it done before as well...although it was on a cnc G&L horizontal, and it was just a fixture base because all the shop lathes were *******.
7635tools
Southeast Wisconsin
If your going to be milling steel, I wouldn’t waste time with a 3 in 1 machine. Bridgeport style mills are a dime a dozen on the used market. As said before, the tooling can cost just as much as the mill if not more. Already been down that road.
HanShotFirst
NW Nevada
HanShotFirst
NW Nevada
Buying an old/cheap Bridgeport is a dicey proposition for someone who doesn't know machine tools. For a first time machinist, I'd stick with something simple and probably new. Once he knows how everything is supposed to work, he can then learn how to evaluate a Brideport and upgrade at a later date.
HanShotFirst
NW Nevada
That's the standard line, but it really depends on what you're doing. If I had to choose between my mill or my lathe, it would be a rough call to make. Sure I can mill on a lathe, but it's FAR from ideal. I tend to do much more milling than lathe work... But I've noticed that my mill tends to make things I want. Whereas my lathe tends to make things I need; and gets me out of binds.
jonesg
northern Maine/
May I remind you it's a felony to buy a mill before owning a lathe. :beer:
