Bench top teardown tray?
Sumboodie
AK
Anything exist?
I had to pull a valve body apart and man it made a mess on the bench.
I know full on tear down benches exist, but how about maybe a 2-3ft wide "tray" that could simply set on an existing bench?
Just needs a slight pitch and a drain catch.
Yes I know I could make something, but rather not spend days of my time if there's something available... and Velvor copied for $19.99 🤣🤣
Gutman
ENC
I use a pan I got from a local auto parts store years ago. It's like a baking pan in construction, but at least 2' x 3'. I think it was marketed as a drip tray/pan.
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
I was thinking if you were looking for something for under the bench (say you grabbed an smaller, stainless steel restaurant table, you put two legs just a bit higher for angle and a piece of guttering under the table with the hole to drain into.
driftpin
One I use.
I also have a fiberglass tray about 20" X 32" X 3" H. I use that for tearing-down banks of multiple carburetors.
Sumboodie
AK
^^ A full sheet pan is 18 x 26 and around an inch deep. Enough for a valve body, I'd think.
Coincidentally a fellow has been offering exactly what you are after: https://chicago.craigslist.org/chc/tls/d/oak-lawn-stainless-steel-transmission/7826153256.html
Sort of. It's missing a drain and the sides need to be maybe 1/2" tall and maybe 2x3ft.
Like a large drop tray that has a pitch and a drain.
Just like a teardown table, but temporary/portable.
Valvebody probably had a quart of hydraulic oil in it that mostly drains only after pulling apart. Same with pumps, motors, transmissions, cylinders, etc.
End up using a ton of absorbs, working in an oil pan, etc.
dscheidt
I've always used a baking sheet, with the back slightly elevated. fluid runs to the front, where you can either wipe it up or **** it up. a full size sheet pan holds two gallons, so it's more than enough for what I've done.
I see the attraction of what you're after, but it would be hard to store, and if you used it enough, I'd think you'd use a permenant set up.
Sumboodie
AK
No harder to store than the pan you're talking about.
gamescastspencer
Saint Peters, MO
I rebuilt the 904 for my Dart on a steel drip tray on the bench. No drain, but not a big deal to wipe up to clean as needed or clear off and drain. For the occasional job like this, hard to beat I think.
Picture from when I tore the valve body down.
Sumboodie
AK
I tear down valve bodies and other fluid filed things on an Absorbent Mat. For engines I use a couple.
So did I but it still makes a big mess.
Plug they're supposed to be disposed as oily waste, not in regular trash.
Sumboodie
AK
I was talking about hydraulic valve body.. aka valve bank.
One I was working on had 5 sections, maybe 30lbs.
PCustoms
VT
Anything exist?
What's a velvor?
Sumboodie
AK
I think the real GJ answer is to buy a box and pan brake, a TIG welder, maybe a bead roller and some stainless steel sheet and make your own.
I've been home like 3 weeks total since May... yeahhhh
whateg01
doo dah, kansas, usa
It isn't hard to add a drain to a commercial baking sheet. Put a block of wood under the back and it'll drain. Isn't going to take a week to do that.
crewchief888
NW indiana
at my previous job i rebuilt a LOT of components.
all types of valves from basic spool valves to orbitals and trans control valves.
i used aluminum baking sheets and old commercial type coffee pot baskets for washing parts
