Bend Pak cable sheeve bushings
goforride57
Upstate NY
I don't want to sound cheap, but, before I drop 180 bucks for 4 new sheeves. I'd like to ask if anyone can recommend some where's I can buy bushings for these sheeves? The outside diameter is exactly 1" and the inside diameter is approximately 3/4". Again just hate to throw away good cable sheeves that have bad bushings.
larry_g
oregon
Just about any place that sells bearings will have a bushing for you. Ace hare ware and NAPA may also have them. I would also suggest that you mic the pins to check for wear.
lg
no neat sig line
crf731
any machine shop or buddy with a lathe can make you new bushings if you take them the sheave and pin for it.
killahog
Morrow County Ohio
Check McMaster Carr they sell a bunch of sheaves. The currently have the small 1" ones that fit the 3/16 safety cable and theirs actually have bearings. I think they cost 4 bucks each.
600SL
Connecticut
What model Bend Pack is that. My HD9 4 post has pins over 1" in diameter.
I vote McMaster on the bushings.
G
goforride57
Upstate NY
Google, or Bing or whatever search engine you like the following and you will have many choices,
1" od 3/4" id bushing
here's some 1" long ones
http://www.ebay.com/itm/Oilite-Bush...676?pt=LH_DefaultDomain_0&hash=item2a4a55396c
Just for an update, I purchased these bushings and turned 1/4" off in the lathe and installed. Nice and tight fit. Thanks for the info. I would have went down to the local NAPA for bushings. When they got bought out a couple years ago, all the employees left and now are stuck with a bunch of guys that couldn't pour piss out of a boot with instructions on the heel in red ink.
The shafts still had the blue powder coat on them and no damage.
