chris fresh
Chris, I prefer 3/16" to a 1/4" max depending on the arc as it's easier to work by yourself in setting and clamping into the form. If you do briefly steam them (which will make them more pliable) then your working time with something like Gorilla glue is shortened as it reacts to the moisture in the wood to cure.
I also like titebond glues and their III product has around a 10 minute open time which would give you some time to level and "make flush" the strips while they are clamped in the jig. A roller, plenty of clamps, an extra set of hands (especially someone that doesn't mind four letter expletives when something does blows out from the clamps - maybe that just happens to me) and some cold beer waiting and your good to go.
A little advice that you probably already know... Make the strips a little wider then the finished width so that you can rip a clean edge to more easily take stain. Less stress than trying to keep glue off and easier to joint/ plane level one side and rip to final width.
good advise,i think i'm going to make them 3/16 with a little steam.i have plenty of clamps and a second set of hands that will get a slap if he doesn't do what i tell um.plus,he drinks PBR,so he's a cheap second set of hands.LOL.
as for the glue,i'm going to look at the III tightbond,i've had really good luck with it and i'm the kind of guy who sticks to what has worked before.as long as it is weather friendly.no problem on getting a good starter edge also,i'm screwing the jig down to my subfloor with a couple of layers of newspaper between the casing and the floor,because of glue sqeezing out.
i plan on making it 3 1/4 wide so i have room to trim down to 2 3/4,then i will face it with 1/4 material,making it 3'' finished.the 1/4 material will hide the laminating.think there will be any issues with the tightbond and moisture? or should i just go gorilla?
