Bending Aluminum Stock
TheClaw
Chicagoland
I installed an Odyssey PC925 this weekend and made a hold down out of 1/8 x 1" anodized stock. I made the bends in my vise. I must have made them too sharp because I'm getting stress cracking on the outside of the bends.
Any suggestion on how to bend the bar with more or a curve to it or less stress? Don't feel like investing in any expensive metal brake or anything like that right now. Just looking for a kindler gentler bend.
<a href="http://www.flickr.com/photos/stufffromthekilinskis/8919525312/" title="IMG_6359 by theclaw900, on Flickr"><img src="http://farm9.staticflickr.com/8117/8919525312_9f98826422.jpg" width="500" height="333" alt="IMG_6359"></a>
Thanks
bhalv
Boise Idaho
I would leave it as is, or if you want you can try some heat to help the metal along next time. It's not like you're making structural pieces or anything.
T
TheClaw
Chicagoland
I like this. I figured I'd keep it as is and if I saw it cracking some more, I'd make another bracket trying a different method.
rharman
SoCal
I use these. Seem to work OK for light duty. I think I got them from Rockler or Lee Valley.
MP&C
Leonardtown, MD
That could have been 6061 alloy, which is less friendly to sharp bends and prone to cracking. Anodized finish does not like bending either, so part of what you are seeing is part of that. For better results with sharp bends, use 5052 alloy.
T
TheClaw
Chicagoland
Roger, Those look pretty slick. I'll have to find those. I track this car and I'm going to bet at some point these bends might break. The one pictured is the second piece I made. The first broke while I was adjusting the angle of one of the bends. I cant imagine it's that strong once it's bent and may give way.
I picked this material up at my local Ace Hardware. I'll see if I can come up with some 5052.
Thanks for all of the help.
Jeff
The alloy has more to do with bending AL than anything. Some alloys would have broken completely on a 90° bend.
Crusty Nut
Anneal it first, bend it, and the act of bending will harden it back up. But some 5052 would be a better jumping off point.
Crusty Nut
I don't work with aluminum all that much and when I do it is usually just a simple bracket. My local scrap yard always has old roadsigns for scrap price. That is mostly all I use. I don't know he compound, but that is some hard stuff. It will crack or just break off with a bend like that. But, after annealing you can almost bend it with your hands.
jmarkwolf
Southeast Michigan
The hardware store will be unlikely to tell you what the alloy is.
Find a shop in your area and buy 5052 alloy, or order it from Mcmaster Carr.
It'll bend much nicer.
bczygan
DETROIT! Arsenal of Scrappers
Got a torch set?
Torch anneal it, and bend in a wood V-block form with clamps , a drill press or an arbor press (Maybe even a stout bench vise). Or rig up a hydraulic press of some kind.
T
TheClaw
Chicagoland
You're right. Even the label didn't identify what alloy it was. there's a Metal Supermarket near me. Only problem they have pretty limited hours. Have to catch them on a day off.
Got a torch set?
Torch anneal it, and bend in a wood V-block form with clamps , a drill press or an arbor press.
That sure beats ordering the metal tool from Veritas. A short piece of hardwood would be an easy tool.
retrobuilder
Alpharetta GA
Heating should not bee required. As mentioned by others a 5052 is better and easily cold formed. My experience with hardware and big box store aluminum is the hardness and lack of bending ease.
2000 and 5000 series are good. 6061, 6063 and 7075 are very prone to cracking.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
6061-0 will bend easily as it is soft. What you are bending is likely along the lines of 6061-T6 maybe which is hard and you WILL get stress cracks. Also, you don't want your inside radius any smaller than the material is thick, so if you want to bend something that is 1/8" thick, you want to bent it around a 1/4" rod, if it is a material that is bendable. Once you get into the "T"'s as in T4 or T6 you are going to have problems.
Stay completely away from any 7000 series as it is going to be harder yet.
I would say that with the stress cracks that are showing now, and you won't be experiencing movement other than vibration, you should be fine without it breaking off.
This man knows his stuff ! From Wikipedia
5052 aluminium alloy - 5052 is an aluminium alloy, primarily alloyed with magnesium and chromium. It has good workability (can be bent easily), medium static strength, high fatigue strength, good weldability, and very good corrosion resistance, especially in marine atmospheres.
6061 aluminium alloy - 6061 is a precipitation hardening aluminium alloy, containing magnesium and silicon as its major alloying elements. It has good mechanical properties and exhibits good weldability. It is one of the most common alloys of aluminium for general purpose use. It is commonly available in pre-tempered grades such as 6061-O (annealed) and tempered grades such as 6061-T6.
