jonness
Will the weed burner torch cause you to fail an inspection? I used it in several spots on my 135' long 2" conduit run and also bent the wide sweep 90's at the ends. Pretty easy once you learn first by scorching a couple of practice pieces. Fortunately, there are no burn marks on my finished pieces.
What is the risk of failing an inspection when bending with a weed burner?
