Bending Sheet Metal at Home?
paramud
Denver, Colorado
What do you guys do to bend sheet metal at home? I am mainly looking at making pans and misc brackets.
Option One
Harbor Freight 20 Ton Press with Swag off Road finger press
http://www.harborfreight.com/20-ton-shop-press-32879.html $150
http://www.swagoffroad.com/20-TON-Finger-Brake-Heavy-Duty-DIY-Builder-Kit_p_86.html $300 (heavy duty version)
Total Cost: 450
Capabilities
19.25 in Wide Limit
19" = Full bending width of the bottom die on anything 3/16" or thinner.
15" in 1/4"
13" in 5/16"
11" in 3/8"
6" in 1/2"
3" in 5/8"
I will never see myself bending 3/16 full bending width currently, just want that capability.
Downfall.
19.25 Bending width. I can see myself bending a pan that is longer than that.
I am planning on making a toolbox, so I need something that can bend at least 50in wide at 16-18 ga Mild Steel.
Should I just get the harbor freight kit and then weld the flanges that are to long to bend? I can also use the press for bearings.
Another option is a dedicated Pan break, but they seem large and take up a lot of room for one purpose. Any suggestions?
nine4gmc
Dallas
Most pan breaks are 30", 48" 120" etc. With your 50" plans, you will be stepping in to HIGH dollar pan breaks by a couple inches...
Have you seen the guys clamp heavy angle iron on a bench, sandwiching the sheet metal between and manually bending it? It's not as accurate but this sounds like a hobby and not a paying job where you could recoup the money spent. Of course, that won't work with thicker sheets but like you said, you probably won't need full width with those.
Whiskeymike
Austin, TX
I just got the Swag HD finger kit. I haven't welded it yet, but it is stout!
For larger pieces of thin stuff, I'm going to make a worktop brake like 94 mentioned. On those pieces, I don't think the fingers will be important. There are some good plans on the net.
P
paramud
Denver, Colorado
Ok thanks guys. Ill do what whiskey said. So swag kit, then stout welding table, then I guess I design a table top finger brake kit.
Thanks guys!
gorilla
In real world press brake work the dies and punch's are determined by material thickness. A punch and dies set that will bend 3/16" material most likely will not give you a bend radius suitable for a toolbox in 18 gauge. Just something to think about.
sz0k30
I just got the SWAG non-HD finger brake a couple of days ago. I went with the lighter duty one cause I'm just a guy who plays in his garage and I don't ever see myself bending more than 1/4". Second I only have a Lincoln 140C welder and the HD version seemed way thicker than that welder could handle. I was even worried about welding the std version.
Well, I have most of it welded up and my 140C with .025 wire handled it with no problem. Its a pretty slick & easy to set up & weld kit.
I bought the gray HF #60603 press earlier this year.
P
paramud
Denver, Colorado
This is all really helpful information guys. Thanks! I forgot about the difference bend radius's I need and will look into the swag radius info.
As far as welding, I am getting the new Lincoln 210, just waiting for them to ship it and I need to wire 210 into the garage.
machine_punk
Napa Valley, California
I went this route...the Baileigh 5216 SBR (Shear, Brake & Roll)
View media item 20569
52" wide with a capacity for 16 gauge cold rolled.
Building a set of drawers for a toolbox is exactly one of the things I plan to do with this.
I got mine at a significant discount (had some cosmetic shipping damage). I've seen the HF SBR's and this is MUCH heavier.
If I had the room, I would prefer a used, heavy-duty, American-made finger brake. As it is, this gives me 3 sheet metal tools in one compact space...which is what I need right now, based on the size of my shop.
Kev
kazlx
Tustin, CA
If you don't plan on going over 16g, this can't be beat. One of the best tools I have bought so far.
