roadrunner255
Hello all,
I had my Bendpak XPR 10A LP installed today. removed the racedeck and had the columns bolted directly to the concrete.
What have folks done regarding arm contact with the racedeck flooring?
One suggestion I found was to crazy glue quarters together under the arm restraint pins.
You still have to manually lower the arms so there is a slight gap between the racedeck and bottom of arms.
Spoke to Bendpak and they have plates to install between the concrete and base. To expensive, they also said that you could have them fabricated.
Looks like for now spacers under the arm restraint pins and base plate.
Cheers!
Cheers!
) a plate that thickness.
