Bendpak 2 post lift install
3x9RT/SE
After much research on 2 post lifts of which one fits my criteria,I ended up going with the Benpak XPR-9FS.Talk about fast shipping,all the way from CA to CT,it left there on Tues,and arrived here on Friday.
Had to wait till Sunday to install it. What a straight forward installation it is with these.More was pre-assembled than the instructions said,so it went alittle quicker than expected.
Everything went together perfectly,my floor was poured in the location of the lifts to be level without pitch,and to my suprise,the power column sat perfectly,both bays,so no shims were needed.The opposite side column was leaning toward the back wall alittle and required me to put in 2 shims on that front edge,and one coming around the side.In and out of the columns were perfect,and once I had the carraiges locked at the 28'' mark,and put on the arms,swung them in to check again for level,it was exactly in the bubble,so the guys that poured my floor did a great job IMO.The floor was poured 7 years ago now,so it had plenty of time to settle out if needed.
Wiring it,I decided to put in a disconnect box right above the motor to have quick access to kill the power to the lift just in case,NTM,turn it off and lock it out so there is no chance of anyone ever messing with it.
The fluid they recommend was either 10wt Hyd fluid or Dextron III ATF,I went with the 10 wt Hyd fluid,came in 5 gal,and good thing as the instructions say 12 qts.,it took just over 4 gallons and is still alittle lower than the dipstick on the plug .That also went well,so far not a one leak!!
Here are a couple pics.
Ohio Auto
Awesome..I was just looking at that exact lift on their website yesterday.
How thick does your concrete meed to be for one of these?
3x9RT/SE
They say for this lift 4'',mine was 6''+.I had to go with this style because of my 10' ceiling height,why were you looking at this specific one???Not that there's anything wrong with it,but if you have the height like in your pic,an overhead would work to,no?I'm just saying,perfect example,putting a ****** in would be better if there was nothing crossing the flor to obstuct you.
brownbagg
I got the same lift but earlier model, the xl-9. that shut off switch is good because my switch was sticking before I smoke it. Its been outside over five years no problem
Ohio Auto
I haven't done any measuring yet for mine..I was looking at both styles.
I have ten foot side walls and the peak in the middle is 15 foot. So...not really sure what lift I'll be able to get.
tonyvlx
Toronto
Is that the narrow version?? If so, any problems when lifting pickups and bigger SUV's??
Thanks
3x9RT/SE
Yes,it is the narrow version,if you want to call 105 1/2'' narrow.I bought this lift with the understanding that it was 102'',but it actually is 105 1/2'' between the columns.The specs say it is 102'' ??????
My dodge rams mirrors are 86'' NOT folded in,81'' if you folded them.I don't see a problem .The nissan in the pic has 19 1/2'' on either side to open the doors,it was plenty.
Mac
Spokane,WA
I just pulled the trigger on a BP XPR-10ACX yesterday. Should be here Friday they tell me. Sure hope my experiance parallels yours.
e-tek
Saskatoon, SK
Awesome set up you have here. I'm sure you'll love thr BP for many years to come. I was just detailing mine today! Frsh oil, lubed the wire ropes and wheels, cleaned the crevices.
Mac
Spokane,WA
Without any notice of change - I recieved an XPR-10A lift yesterday. I ordered an ACX lift but they are apparently discontinued and sold out. Nothing on the BP site about changes or upgrades of any kind. It appears to be convertible from narrow to wide stance and the top crossbar is expandible. The cables have a couple of extra nico-presses swaged on so they can be installed for either stance. The install manual is for the 10A but again nothing indicating differaqnces from the ACX.
