BendPak 4-Post Leveling Question
Bluewolfcry
Hi guys,
We moved to our new home a month ago and I finally got around to re-assembling the lift. Everything is put together and seems to be working properly. Only difference is, this time I plumbed/shimmed the posts, leveled the ladders and synced the cables. I figured this would reduce the anxiety and nightmares I have of my car falling through the garage walls.
At our old house, I did not compensate for the slope. No shims - just raised the ladders 1 cm off the post and synchronized the cables.
The problem: there’s not enough slack in the cables to fully compensate for the slope. The aluminum ramps barely touch the garage floor when the lift is down. See pics.
There about a 0.5-1 inch gap at the ramp. Is this ok? Essentially, the cables would be under load the entire time down. I often parked my car on the lift without raising. If this is a problem, how should I address this?
Thanks in advance!
Tony
pbon
I would probably skip the shims under the post floor plates. I would use a laser level to try to get all the ladders at the same height.
Always activate the air first when raising or lowering, especially lowering.
Bluewolfcry
Pbon, the challenge here is I would still have this cable slack issue, even with the shims out. If I adjust the ladders to NOT be level, but parallel to the floor slope (which is what I had before), there would be ample slack for the runways to touch the floor. However, I don’t think that’s the correct way to operate?
pbon
If the ladders are not level will the locks engage at the right time? As long as they do, would there be any issue with the operation of the lift? I don’t like the cables holding one end off the floor. That is probably not ideal for the ramps, either, since they would be supported only at the ends.
I think my floor has some slope but I forget how much. I was able to level the runners and ladders pretty well so my slope must not be as bad as yours. Before I did that leveling, I had a couple of bad experiences lowering a car. One post started tilting in. The cable was loose under the runner. I found that always engaging the air release before depressing the lowering handle helped.
wssix99
Chicago, IL
I'm in the same situation. I created a pattern of the base plates, had a local shop cut them out of 1" steel with a plasma cutter, and then I painted them with a can of BendPak touch up paint. While they were at it and set up, they cut me some thin shims out of other thicknesses and I was able to level the feet all perfectly and precisely.
Everything installed easy.
Bluewolfcry
Interesting....Did you weld the pieces to the post and are the ramps still able to touch the floor?
