Do those of you with the HD-7 or HD-9 have any suggestions as to which length is better and to options? I will be getting the wide version since I work on my cars and may sometimes drop a motor or trans from the bottom.
I am torn on runway length. The shorter HD-7W gives me more workshop space in my 23x28 garage, and 99% of the time, I will be lifting smaller cars -- BMW E36, BMW E60, but may buy an SUV like the BMW X5 in the future and may very rarely lift a Suburban. No dually quad cab long bed trucks for me.
I have learned that the new RJ-4500 bridge jack is not a good choice for low cars -- the center section grew in height as part of the certification process. I have to find a compatible rolling bridge jack and there are a few that may fit, but I need to figure out how their wheels sit on the Bendpak rails to determine the minimum height above the runners (and likewise, it cannot hang down too low or I won't be able to lower the lift all the way to the floor).
Also wondering about the bottle air accessory versus using a compressor. I have compressors, but don't know that I want to run one every time I use the lift and don't yet know whether I will end up with a manual or air bridge jack.
Tempted by the caster accessory, since being able to move the jack a little would be convenient. I may locate it slightly differently on the rare occasions when I lift a Suburban, to better fit the cutout I am making in my ceiling for maximum lifting height, and also don't know exactly where it will fit best in my garage. I have a general idea, but not precisely.
For the ramps, it has been recommended to use the plastic race ramps since they are even lighter than the extended aluminum ramps and I will be removing them rather than leaving them attached when the lift is up.
