BendPak 9xw 4post lift
Dustybutt
:How to wire motor, blk/wht/grn after switch.
Switch norm closed(not used) norm open / common
Do I wire blk/ wht/ after switch?
Never hooked up switch like this!!
foolio
Pendleton, IN
230/single phase? If so, you need a two pole breaker (20 or 30 amp) with 12-2 wire. Then, WHT/WHT, BLK/BLK, GRN/ground. Label the the line white with red tape or heat shrink to indicate it is hot, not neutral. Consult your owners manual for exact power requirements. If you don’t have it, I bet you can download it or at least contact the manufacturer.
matt_i
Need some more info. Pics would be extremely helpful of what you have, to include the motor nameplate. The necessary input voltage 120vac or 240vac is needed.
