BendPak Drooping floor ramp Fix
NitroShark
Greenville, SC
I originally bought the optional Bendpak ramp brackets. They worked well but did not raise the ramps to max lift. I tig welded some tabs to them and added some valve springs to hold them up to Max height.
Worked out great, so I thought I would share the idea.
Shawn
Photo shows the modified lift springs added on the right and stock brackets left.
Matt M PA
SE PA
The ones I got seem to be different than yours....but Ill take a look tomorrow to see if I can adapt this idea. Thanks!
I got the longer raps and they droop way down with the pieces I got...
usa#1
I have a rotary 4 post. My ramps do the same thing. I just cut a couple pieces of 1 x2 's that I place in between the stops on the ramp where it contacts the lift. When I want to "lock" the ramps in the horizontal position I lift the ramp, insert boards and let the ramp stops dig into the wood pieces. When I need to use the lift I just remove the wood strips.
Matt M PA
SE PA
Shawn...my ramps drooped much further than yours...too low to drive a vehicle underneath. Out of sight...out of mind...I completely forgot about this. I'll post a pic of my pieces today...
Matt M PA
SE PA
Okay...here are the pieces I got for my lift from BendPak. I ground down a little bit so they'd clear the tubes that hold the vacuum lines on the lift.
They allow the ramps to droop so far that I can't drive even a low car underneath. If I have one regret with what I got from BendPAk...this is it. Absolutely worthless.
N
NitroShark
Greenville, SC
Yea, they are different than mine from 2012. You can see them before I welded to them in the photo below.
I bet they will send you the updated ones if you call customer service?
Bendpak does respond to problems well with results or answers from my experience.
Shawn
