Bendpak HD-7W 4-post cylinder weeping
Relax
GTA, Ontario
I've had my lift for just over 10 years now, and noticed recently that there's an occasional drip of ATF on the floor from the end of the hydraulic cylinder. I only use the lift once a month, if that, and then it's usually left in the fully raised position with a car stored on it on the locks. I used to release all hydraulic pressure, but a few years ago a friend recommended that I leave a little pressure to make the seals last longer (I've heard the same about not leaving your suspension fully drooping for the same reasons).
Anyways, if I have to clean up a drop of fluid once a month, no big deal. My only concern is whether this can lead to a sudden failure where the lift will suddenly drop whatever I'm lifting (even if only down to the next safety stop). So I guess my question is, at what point should I start considering repairing/replacing the cylinder?
Imatk
You probably have a seal that is leaking due to age. Call Bendpak and tell them what's up. They probably will give you the option of buying a new ram or seal kit.
