The Wizard
- Joined
- Apr 9, 2010
- Messages
- 88
Fellow garage enthusiasts,
I recently bought and installed a Bendpak HD-9 four post lift. All it needs is some power and it will be alive!
First, is this a DIY job? I've received estimates in the $400 range but would like to do it myself for multiple reasons.
If it is a DIY job, would you be so kind to review the attached schematic and let me know if this makes sense and if it's possible? If so, hopefully you guys can point me in the right direction so I know exactly what to buy at Home Depot.
Thanks in advance. James
To try and put the picture in the fewest words possible...
The HD-9 is on the same wall as my main panel to the whole house. I'd like to connect the HD-9 as shown in the picture with a plug type connection. I also plan on installing an AC/Heat unit above the door in the near future. The AC unit requires 240v as well. The receptacle at the bottom will remain unused but available, and will only be used seldomly for a Millermatic Welder or anything else I come across. I also purchased the air/electric workstation from Bendpak as illustrated. Hopefully that can be run off the same line as the 240v, or will it require it's own line?
