kitdoctor
I've been working on installing my four post hoist and finally got it wired up with the help of a friend, plus hooked up my new compressor. Anyway hit the raise button and the motor is getting power but the ram is not tightening the cables.
Call my buddy electrician back and we worked out the motor/pump is running backwards. So fix this and I raise the lift to full height for the first time, yahoo! He suggests we test the air powered main safties and lower the lift to the ground. This works fine. He then departs and I continue with final minor tasks.
I then try to raise the lift for the first time and half way through this the motor stopped. Now it's acting like it's not receiving any power because when I hit the raise button the motor doesn't operate. I haven't thrown a circuit breaker in my home's power board. The trouble shooting part of the manual suggests the motor is burnt out, a micro-switch is burnt out or wrong/low voltage. I'm in Australia and the voltage is 240 V AC here. The unit is on a five meter extension cord which is connected to a 15 AMP electrical outlet.
What do you guys think has gone wrong and why? Any suggestions? Where's the mirco-switch?
