Quijote
My lift just got installed and as was putting the Racedeck tiles on, I realized the arms don't clear the 1/2" thick tiles. Sadly my lift is not wired yet, but I assume that once wired, I can just raise the arms, put in a 1/2" thick steel spacer plate and then have lift rest on the spacer 1/2" higher than originally. Naturally I'll have to adjust the cable tension to remove that extra 1/2" slack on each side.
Do any of you see anything wrong with this plan?
