I bought the MDS6K and have gotten to the point of filling it with ATF and attempting the bleed procedure, which is to simply raise and lower the lift several times. What is happening is only one side raises. The other side won't begin to raise until the other side is maxed out on height. But it gets stranger. When you lower the lift partially and try to raise it again, one side will raise while the other side simultaneously lowers. I doubled checked the hydraulic schematic and have made sure the flow divided is hooked up properly.
Does anyone know what the hell might be going on?
