Just get my XPR-10 lift assembled and working.
Everything is working correctly with exception of the the 'off-side' safety latch. I cannot get the safety latch to move enough to allow the carriage to go down.
In its relaxed position it appears that the safety latch goes to far into the lift post, in fact it goes in so far that the safety latch actually touches the lift cylinder. The power-side has at least 1/2" clearance between the safety latch and the lift cylinder.
If I adjust the off-side safety latch to reduce how far it goes into the column (by adjusting the cable), there is still not enough throw to allow the safety latch to disengage/clear the lift column.
The safety latches both work smoothly and easily move by hand. The cable is routed correctly and it not binding on anything. The pulleys are not binding.
I think the off-side safety latch might have been mis-made as the horizontal bar welded on the safety latch does not touch the column as it does on the power-side (or the pivot hole was drilled in the wrong location).
Can someone with a XPR-10 lift take a look at the pics below and tell me if your safety latches looks like mine when installed?
I will call Bend-Pak on Monday.
Thanks!
-steve
Thanks!
-steve
