I wish I had found this post 3 days ago. I am so frustrated with the BendPak installation directions. They are beyond awful. I, like a few other people here mounted my power side on the left, because the manual specifically says you can choose which side the power side is. I have a wall to contend with so it made sense to put it on the left.
My problem is that the release lock cable has such a diagonal skew in it now that it is impossible to get the far side lock to release (even with my entire weight on the release lever).
I called BendPak and they told me I installed it incorrectly. I asked them where in the manual that something that important was specified. They told me I was supposed to infer this from one of the pictures (the only one indicating the approach comes after the posts are installed in the steps). I asked them how I could trust the pictures when my electrician had to reverse engineer all the motor wiring as the diagrams were not at all correct for what was in the lift (different contactor, added capacitors, and different terminal numbers).
Now something that I have not seen mentioned yet (and I should start a new post) since this is in my garage I went with the narrow configuration, why wouldn't you to conserve some space and keep the floor plan more open. Well something else that should have been on page 1 is that the narrow configuration is worthless. It is not possible to lift my car (Subaru) with the narrow configuration, the arms won't reach the lift points. So add to my fun list of things to do, now I get to cut off the bolts and move to the wide configuration as well as pull the other post so the cables will route properly and have my electrician come back out to move all the wiring.
BENDPAK why are your directions SO HORRIBLE. This is exactly what I wanted to avoid, why I bought a USA made lift, why I paid a PREMIUM price for a lift and not some cheap Chinese lift. I even contacted a local professional installer and he had no idea the asymmetric lift had to be installed with the power side on the right.
An install that should have taken 5 hours will now likely take me 4 days because of the deplorable documentation. And honestly they could have engineered it to go both ways by making those rollers centered on the post.
An update for the manual should state:
1. Power side needs to be on the right
2. Use the wide configuration.
