Benjamin Moore Corotech Expoy Floor Info
ddausilio
Residence
This week I decided to resurface my 3 car garage floor with epoxy. After reading many reviews and speaking with local painters I decided on Corotech. Several threads here and elsewhere discuss the benefits and results of a properly prepped floor.... so I rented a floor grinder with diamabrush attachment and wet grinded the floor. Another thread mentioned 6 hours... I said no way I can do it faster... Well 6+ hours later the floor was ground.
With step 1 completed I let the floor dry for 2 days. First day was beautiful, 75 degrees and low humidity around 45%... next day I left a dehumidifier running full steam to get the floor bone dry...
Step 2 was to apply Corotech V-155 primer. A two part mixture 3/4 to 1/4 mix ratio and comes as a kit. Mixed for 5 minutes and let stand for another 30. This produce sucked into the floor pretty well and it took 2 gallons to cover my 3 car garage, approximately 750 square feet.
(NOTE: THE PRIMER DRYS PATCHY) - Some spots look as if nothing was put on and others like too much... but it was applied evenly, or as evenly as a 9 inch roller can put it on.
(WARNING: Even thought the floor was ground down... there still existed little fish eye patches where paint was below the surface of the grinder (see pics). The chemical primer made these little chips soft and they bubbled so I said "Hello" to another two hours on my knees scrapping these little suckers down with a paint scraper..)
Step 3 was to apply Corotech V-400 epoxy (Battleship Grey). A two part mixture 1 to 1 ratio. This comes in gallons only so a 5 gallon bucket for mixture was helpful. Same mixing and 30 minute wait. Rolled on smooth although spreading flakes was a challenge as I never did it before. My advice is to fling those flakes with determination into the air for even distribution. I used 12 (12 oz) cans of flakes and two gallons of epoxy (1 epoxy and 1 catalyst) covered the entire floor well.
Step 4 was to apply Corotech V-400 epoxy (clear coat). Same drill as Step 3 however I warn you. It was early impossible to see the wet and dry areas. I did not use spiked shoes and it was a challenge covering the entire floor.
In closing I hope the effort was worth it and the floor wears well and no "hot tire" occurs... My first post .. hope it was helpful... Pics below..
BULCHE
paraumus
so hows the garage floor holding up?? Thanks for the pics and review. There are not many reivews on these products form COROTECH and i've been wanting to stay clear of Rustoluem,s epoxy.
i'm considering using this since i like Benjamin moore products.
But have you heard reviews on the Urathanes from COROTECH? I spoke to the company and they said with would be overkill for home garages. But if i'm spending money and working hard to apply something, i probably wouldn't mind the "overkill" part.
Does the Epoxy floor seem like it will last a while? or do you think i try the polyaspartics or poly urea, urathanes.. etc from COROTECH??
D
ddausilio
Residence
Bulche: In reply to your question, the floor, as of today 3/7/19 has held up perfectly. We drive 3 cars in and out of the garage daily and it looks brand new.. No "Hot tire".. No scratches. Because it is winter here in Connecticut I mop the floor after each snow event because I don't want the salt and sand that drops from the wheel wells to act as an abraisive and damage the floor. I am not even sure if that is necessary but I am a little protective of the floor after all the work. I would follow my original post steps... and remember to grind... grind... grind.. make that surface perfect and dry before applying. Best of luck. David
moose82
New Jersey
ddausilio, your garage floor looks great! I am also in the process of purchasing the Benjamin Moore Corotech Epoxy, and plan on using the same setup as you. Did you use a semi or high gloss sealer over the flakes?
and you were able to use the one v400 mix (1 epoxy and 1 catalyst) to do the entire floor? no recoat was necessary?
And how does it look almost 3 years later
thanks again
D
ddausilio
Residence
Moose82.. I do not recall an option on "Gloss vs Semi Gloss". I remember using only 1 kit of V-155 primer and that covered the entire 3 car garage with plenty left over. I think I used 2 gallons V-400 for the floor then flakes and 2 Gallons of V400 clear for the top coat.
It has been almost 3 years and the floor is driven on daily many times. It looks brand new!! No wear at all.. No scratches.. Nothing... I pull all cars out and mop with soapy water 2 times a year..
A lot of work, especially the prep... but was worth it... Good luck with your floor..
Mge2093
David - Thanks for this update - really helpful to hear how its holding up.
D
ddausilio
Residence
A few photos after 3 years
