Bennett 457 "Lubesters"
JAWs7227
So. IL.
Hey all, I have two Bennett model # 457 lubesters with Shell embossed lids, I'm wondering what time period this model was manufactured, and if theres a source out there for pump parts, one is siezed completely and missing parts and the other cranks but doesnt pump anything up. Thanks.
Provincial
Near Salem, OR
Take the worst one apart and find out what is wrong. Just looking at the outside, it appears that the crank runs a pinion that engages a rack attached to a piston. The piston would run up and down in the cylinder of the pump.
To operate, you crank on the handle, raising the piston until it stops. That should be one unit (pint or quart probably), and then reverse the crank to lower the piston. Repeat until the desired amount has been pumped.
There will be a packing around the piston, a packing around the operating rack, a packing on the crank handle, and a couple of one-way valves. As old as those are, I doubt that the packings will be fancy, so you should be able to make something that works from bulk materials.
It looks like a fun project!
1982fxr
Phoenix
Just guessing...
Wwii ish.
There is a site for petroliana collecting those guys can help
J
JAWs7227
So. IL.
Thanks for the info, I wasnt aware of how they worked exactly so thats helpful.
The guys over on oldgas can tell you anything that you want to know about lubesters.
Thanks, I'll check them out.
