compaddict
I'm using Husqvarna TitaniumForce trimmer line and it is the best I have found. Any wisdom?
Oregon Magnum Gatorline is the best I've used. The square cuts better than the round and available in .105 dia. Used to use it alot cutting right of ways when I worked for municipal maintenance
Rotary black vortex (available on Amazon) is head and shoulders above anything else I've found.
Way better than the above mentioned Echo, Husqvarna and Oregon, all of which I've used in the past.
That looks like the Echo line but some reviewers say it doesn't hold up well. How does it hold up for you?
Try this trimmer head:
https://www.amazon.com/gp/product/B008G4GRNQ/?tag=atomicindus08-20
It works so well!
I'd skip the string and install a brush cutter blade for that stuff. I had to do it for some really fibrous stuff here as well.Ok, I order the Rotary black vortex: https://www.amazon.com/gp/product/B00ITYSY70/?tag=atomicindus08-20
It's not working nearly as well as the Husqvarna titanium force line, in fact it doesn't last 25% as long cutting through the heavy weeds I'm dealing with. It is much quieter though, which I completely do not care about. The breakage issue appears to have been the result of worn eyelets in the trimmer head, I turned them 180 degrees and the problem is gone with the Husqvarna line but is still a problem with the vortex line. I've posted a few pictures just to show the nasty stuff I'm having to try to cut through. I'm fully aware a brush blade would work better but this weedeater has no clutch, I have two of them and I've broken two flex shafts on the other one given the additional weight of a blade and the harmonics that drive it into a violent backlash jerk which it can't overcome.
