Best 30 gallon, vertical, oil-lubricated, compressor?
Compressor
Needing a new compressor. Looking for the best 30 gallon I can find. Need vertical, oil-lubricated, quiet, unit. Preferably runs on 110.
Home shop - not looking to spend 1000's but don't want cheap junk either.
Appreciate any suggestions!
zakmartin
Seattle, WA
I love my Craftsman Professional 27-gallon oil-lubricated upright. It's built like a tank and hasn't let me down in the 7 years I've owned it. I've done a few light modifications to it (i.e., added a drain stem at the bottom and put in a better air filter.) I got it at a bargain when they had it on sale. I think I paid about $300 for mine.
C
Compressor
Sound like a steal at $300. Right now it's about $600. I'll keep my eye on it for sure.
bcradio
New Mexico
I got my craftsman pro 27gal for around $350 and love it. Very reliable and the vertical takes minimal space. I also added the drain to the bottom which is super handy.
Hondarancher4435
this really depends what tools your wanting to run I also have a craftsman 30gal and and frankly I feel its junk. it has such low volume if you want to run any tools impacts, saws, sandblasters, sanders get something bigger. if its just for hobby work its fine but for any real shop work most of your time will be spent waiting for the compressor to fill back up.
1950mercury
metro detroit
Um who would buy a 30 for a real shop?
Rlfd213
You can buy a 60 gallon oil filled sanborn from menards for 450.00
jallyn
Fort Wayne, Indiana
Anybody have the Sanborn compressors? Even the 80-gallon is a low price compared with Harbor Freight. They are assembled in the US from global components (and Swedish reed valves). Half tempted by the price...
zakmartin
Seattle, WA
The red Craftsman 30 gallon and the black Craftsman Professional 27 gallon are very different beasts. For example, I ran an Aircat angle die grinder, which consumes 7.8 SCFM at 90 PSI for about 2 hours once. The compressor was running most of the time and it went without a hitch. Being as quiet as the compressor and the Aircat are, they were a pleasure to use. Mind you, that's well over its rated 5.8 SCFM delivery at 90 PSI. The compressor did nothing but deliver.
I realize that a compressor with a tank this small wouldn't be useful in a pro shop, but I don't have a pro shop and for every air tool I own, the CP 27 upright has been perfect. I change out the oil once a year with De Walt synthetic compressor oil. I've never seen any metal shavings come out with the old oil. :thumbup:
Also, I hooked up a dedicated 120 volt, 20 Amp GFCI circuit to my breaker panel for the compressor since it would occasionally trip the 15 Amp circuit breaker that ran through my house and through the three upstairs bathrooms. I haven't had any power problems since I added the dedicated outlet.
Fixed
Ontario, Canada
The shop I work at uses one, purchased from Princess Auto. It is run pretty hard (used for a large plasma cutting table), and we have done zero maintenance on it other than draining the water out of it at quitting time in the few years I've been working there.
Sent from my SGH-I747M using Tapatalk
dsimatt
I just picked up a 30 gallon husky aka sanborn, aka whatever sticker placed on the tank. I think its a pretty good little compressor and I don't have a lot of time with it but what I've needed it to do so far it has without issue.
At work we have a sanborn one that is pretty much the same and it's a spare/mobile one so its not used a lot but is abused plenty and no maintenance of any kind but keeps on licking.
UpNorther
Brainerd, MN
I have a Craftsman 33 gallon vertical. I think they run about $300, I picked it up off Craigslist 3 years ago for $150.
In my opinion, it's just OK, and its horsepower underrated. 1.7 HP takes a while to fill up the 33 gallon tank.. ex- my 4 gal pancake compressor has 1.9 HP..
I have it on the other side of an insulated wall, so the noise doesn't bother me.
anndel
Hawaii, USA
Just bought a Husky 30 gal which they're delivering next Monday which replaces a California Air Tools 10020 10 gallon. It handles impact wrenches on except the IR 2235.
