Best Air Hose?
i4ni
I'm going to switch to Milton V Couplers and I may as well switch to newer hoses while I'm at. I'm probably going to use 1/4" couplers for the most part but I may go bigger on an tire inflator drop by the overhead door. We have real winters here so the hose must be flexible. Any suggestions?
Buckgnarly
VT
Flexzilla in the shop and on the outdoor reel. Stays flexible down to double digit negatives.
nadogail
Coronado, CA
I regard air hoses as a commodity, just like "regular" gasoline. I buy the "better" grade hoses from whoever sells them cheaper, lately that has been Harbor Freight.
matt_i
Imo the best air hose is Goodyear UltraGrip.
But its expensive. Ive bought cut pieces at McMaster Carr. Designed for heavy industrial/robot cells and lots of byproducts of spot welding (in automotive assembly plants) that degrade the hose.
There's lighter duty hose that's more flexible. The yellow Goodyear 3/8" I bought from Amazon is a decent balance.
DeeKay
Colorado
I get mine from the MFCP (Parker) store, usually just black pushlok hose, holds up great and seems to be flexible enough for me but it only gets down to like 10°F here for the most part. Not sure if you're definition of real winter is Canada cold or midwest cold haha.
coljar
Belpre, Ohio
I use the Goodyear red hoses. I recently threw one of them away that I'd had since 1981. It came with my first Reelcraft.
homebuilt burner
central Wisconsin
I just changed out my 10 year old red Goodyear hoses for Flexzilla about a month ago. So far, I’m happy with that choice. The old ones were getting stiff.
Jking24
I second the harbor freight hybrid green hoses very good for the money and super flexible even when cold
rmack898
Honu Grove NE Florida
I have two hose reels with Flexzilla on them. The first one is at least 5 years old, maybe older. No problems with them in a welding and fabrication shop.
I
i4ni
Are you guys using 3/8" hose with the high flow 1/4" couplers? Old school was 3/8" couplers to 3/8" hose and 1/4" couplers to 1/4" hose. I've been getting by with the old stuff so I'm not up on all these new high flow couplers and air hoses. My old hoses were the red Goodyears and some of those are 30 plus years old lol. The old couplers are ARO {type A} and I still have some new couplers and plugs but if I'm gonna upgrade to high flow I want everything to be the same.
vwpieces
Hills, PA
Flexzilla and Coilhose Pneumatics Flex Eel
Prefer the flexeel with the repairable couplers and it stays clean. Flexzilla gets filthy fast and don't come clean. HFT now has a copy of the Flex-eel mentioned earlier but I have not used it.
tdkkart
Eastern Iowa
I bought a new 50ft Flexzilla while setting up to paint a car, seemed too flexible to me, had trouble with it kinking as I drug it around the car.
LS6 Tommy
Northern NJ
SmartFlex and Flexilla are both Legacy products. My guess is Flexilla is marketed towards homeowners, Smartflex is towards shops/pros.
IDK for sure, but it seems the only real measurable differences (besides price and color) is the SmartFlex hoses have steel NPT ends, the Flexillas are aluminum. The Flexillas also have a fancier bend relief on the ends. Flexila is rated -40°F to 140°F, the Smart Flex is -30° F- 140°F. They are both rated for 300# and have the same 2 year warranty.
No brainer for me if I get new hoses, it's SmartFlex. $12.00 less than Flexilla on Amazon...
Tommy
BearsFan315
Portsmouth, VA
Have a Flexilla Reel on the wall for everyday usage, also a 50ft Flexilla hose if i need to get out further, mainly down the driveway.
also have a crappy blue pvc one that i let neighbor borrow when they need a hose :) not getting my flexilla. plus hte blue pvc came with the compressor when i bought it.
finn
The UP, God's country
I have regular vinyl, the woven fabric covered rubber that came with my sears Craftsman compressor in 1980, Goodyear rubber, some hybrid I don’t remember the name of, and Flexilla, which I think is some sort of hybrid.
I like the Flexilla (and probably it’s knock offs) the best. The unknown is next, GoodYear rubber is mid pack.
The ancient Sears is remarkable though. It’s getting stiff, but only has one repair, made about 25 years ago.
PoorUB
Fargo, ND
I ran a repair shop for a few years and nothing I found would stand up to the grease and oil until i tried Aeroquip push on hose and fittings. The hose it actually rated for oil lines and rated to 300 PSI. I still use the hose I bought about 35 years ago and it is still in good shape. A bit on the expensive side, but when you weight it out over time it is pretty inexpensive! If the working end of the hose goes bad I just cut off the bad section, cut the barb fitting out and shove it into the remaining hose.
Sumboodie
AK
I have a flex zilla style hose but it's blue, almost clear looking.
Not sure the brand, got a 100ft length at our local industrial supply.
txvwnut
Bedford, Texas
I've been happy with Flexzilla. Used to use the yellow Goodyear but it would get stiff in the winter which made it a little troublesome for the reel.
OldracerJones
Chico, Texas
I've always used the red rubber hose from Goodyear but bought a flexzilla hose for our local VFD and what a great hose. My new ones for the shop will be flexzilla.
johninct
I really like the Snap-On Poly hose. VERY Light and flexible. The only thing, I am afraid to use it near welding for fear of a spark hitting it so I use a Flexzilla for that.
Showkey
"MEMBER EMERITUS"
Wausau WI
The “flex” type products (not the brand) often have a common problem that transitions water hose products as well.........many are NOT actually flexible:
The fact all these products are marked contractor or professional is similar to the wash machine marked commercial or HEAVY DUTY.
sweetk30
finger lakes area upstate ,ny
yep that hose in the pic looks like std hose just green . . .and all these fake uses of the terms or names ***** anymore .
rmmiller
Kennewick, WA
Kuri-tec has a couple very good hoses too, their poly air and tundra hoses are very flexible.
Believe it or not, they used to sell them at Harbor Freight !
Those are not the same as the older Goodyear hoses. They are a licensed product by the Goodyear tire division.
The original Goodyear hose products division was sold off to Veyance years ago and was branded Goodyear Engineered Products. Not too long ago that name went away when the hose division was sold again to Continental and branded Contitech.
It's all still the same products, manufactured in the same plants, just different names.
Kaizen
New England
I have a flexible reel on the ceiling. First hose I grab all year. Even my good hoses harden up in freeze temps. I switched to the purple miltons. Like them. Sometimes they get stuck open though when disconnecting.
