While the two kits look the same, it doesn't necessarily mean that they are. Sure, the Astro kit in made in China, as is the Orion kit, but one factory can copy the other easy as pie.
In the unlikely event you have an issue with the Astro kit, Astro will take care of you - usually via a PM to Chris, who, as mentioned, is an active member here.
With "Orion Motor Tech" ?? Who knows. Their website has a "Contact Us" form, no other information. Will you get a response, or will your form entry be lost in the ether?
Astro's website has a similar form, but also has a physical address, a phone number and an email address. Real people respond (I can vouch for that, and their excellent customer service).
Snap-On is regarded as the best and I believe it, but at a price so close to a grand new it isn't something for most.
On the other hand if you are concerned that the Chinese ones are just rebrands than your best bet may be using the "loaner" tools from O'Reilly's or such. That's be free to you.
OTC used to be made in China, but now makes it domestically. I bought this one and it does not bend like the Chinese one that I was "lent" by the parts store. Since these two brands are made in U.S. and look completely different then you know that they are different. I agree that it is a crapshoot as to whether the colors and shapes of the different cases hold substantively different tools.
I would never go snap on sure I have have some gear from them but dam they are over priced company
OTC kit is roughly 500cnd
I would have to research more about quality of their USA versions
It's ******, and they refuse to honor their warranty. I bent 3 of those POS, they cry about replacing failed adapters "that's abuse" - astro all the way.
I avoid OTC as much as a possibly can. YMMV.
I have an older Chinese OTC and it's done numerous 1 ton axles without issue. The one Astro tool I have failed (electrical connector crimper) and they wouldn't stand behind it. I won't buy Astro labeled products for that reason when they can be had significantly cheaper labeled differently. Take it for what it's worth.
