Quick question that I forgot earlier, but I have a 16oz BP that I got cheap, its a no name brand($5)...I've had the thing for a few years and the handle broke a couple months back. I saw a replacement handle at the hardware store for a couple dollars. Is it worth replacing the handle or should I just get another one to add to the rest of the hammers I have?
If you liked it before, then put a new handle on it. Be sure to look at the tree rings in the bottom of the handle; you want them in line with the swing of the hammer for maximum strength. Anymore they just spit them out of a machine and it's a **** shoot if you get one right...
Estwing. It is the best because the whole body is one piece of steel. YOU NEVER HAVE TO CHANGE THE HANDLE OR FUK WITH IT IF ITS LOOSE!
Could you explain a little about the tree rings? I'm not too sure I understand..
I think you want the lines of the wood's grain to run parallel with the direction of the swing instead of perpendicular.
I just picked up a couple of Vaughan yesterday and after looking at them side by side with some Craftsmans I already had, there is no doubt in my mind that Vaughan does in fact make Craftsman hammers, at least their ball pein hammers.I like the craftsman ones (I beleive they are made by vaughan)
Red handle hammers are usuallty Plomb
I think that Vaughn is the OEM for Snap-on for the Blue Point line of hammers.
Initially, Trusty-Cook, Inc., invented and developed the original line of polyurethane Dead Blow Hammers. Over the years, we expanded our hammer model line-up to include Dead Blow Sledgehammers, Ball Pein Hammers, Bossing Mallets and Slimline Dead Blow Hammers. Due to our commitment to quality and manufacturing efficiency, our innovation has been put to work developing private branding relationships with companies such as Estwing Tools, Armstrong Tools, Cornwell Tools, Matco Tools, Snap-On Tools and SK Tools. In addition, we continue to deliver our Dead Blow Hammers to the industrial and retail market under the Trusty-Cook and Trusty Hammers brands.
Also, someone said that Trusty Cook does not make the hammers for SO. Right from theior home page:
Anything worth doing is worth overdoing....
I plan to get some Estwings, some Proto Antivibes, and the Trusty Crook DBBPs...
Hey, it's the GJ way, if one is good, >100 are better...
http://buy1.snapon.com/catalog/item...roup_ID=675296&store=snapon-store&dir=catalog
Pretty highly rated. I'm afraid if I try one I'll want it![]()
Anything I would use a ball pein for (I don't currently own one) I use my pipe hammer. Got the idea on here (in general) but adjusted the flavor. Probably cost me more than actually buying a ball pein but more durable. The head is around 5/8 an inch and square; I was going to use it for slugging in 1/2" but the adapters are too expensive and no detent (so iffy).
I was just sharing another option for guys that like to be against the grain.
My opinion on ball peins (and all hammers) is that you should always buy one piece if possible if you're going to use it a lot. Don't have to worry about the head flying off or the fiberglass shattering. Lots of companies make one piece hammers nowadays but they're kind of pricey.
An old timer trick for making paper and thin cardboard gaskets was to gently tap the outer periphery of the material against the gasket surface with the ball end, then do the holes, and then the inside of the pattern. the edge of the gasket surface would cut the paper/cardboard and you would have a perfectly fitting gasket.
It actually works quite well.
Besides that, even mechanics and definitely body workers need to form metal at times. Body hammers are great for metal repair but if you are dishing out a section of metal, it's hard to beat a good ball peen.
Lastly it used to be used for strain relief for metal parts. I never learned the details, but again another mostly lost skill.
Mac/Proto Antivibes and never look back.
Is the cman made by Vaughn? I like the Cman wooden handles.
