I like the ratcheting ones for my application (135 KW of DIY LiFePo4 batteries and four inverters and three AC coupled line inverters) cause many of my wires needed to be fairly accurate in length with each other, but I can see how they wouldn’t be the best for a sparky for production.I use these because they are faster than screwing around with ratchet cutters.
Ideal 14" Cable Cutter, Shear Cut 35-031 | Zoro
Order Ideal 14" Cable Cutter, Shear Cut, 35-031 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.www.zoro.com
When I was younger and didn't have money to spend on fancy tools, it took both hands, but I used these for at least 100 services, cutting three 2/0 copper conductors on each one
Greenlee 9-1/4" Cable Cutter, High Leverage, Shear Cut 727 | Zoro
Order Greenlee 9-1/4" Cable Cutter, High Leverage, Shear Cut, 727 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.www.zoro.com
I have two sets of ratcheting cutters, one set for up to 400 MCM, the other for up to 1000MCM, but the whole process from opening the jaw to the finished cut on one wire takes longer than lopping through three using the shear type.
Battery operated angle grinder. It will cut ANYTHING !
theoldwizard did.No , didnt say battery operated.
You didn't get Greenlee 727's. From my experience with Greenlee, Klein, Channellock, and Ideal, the Greenlees are the best, but not by much. None of them will cut 2/0 with ease.
I have both Greenlee and Klein and agree.You didn't get Greenlee 727's. From my experience with Greenlee, Klein, Channellock, and Ideal, the Greenlees are the best, but not by much. None of them will cut 2/0 with ease.
Hand-Held Cable Cutter | Greenlee
Find product features, specs, documentation and where to buy information for 727 Hand-Held Cable Cutterwww.greenlee.com
I have that same set. I use em on about 2/0 up to 535MCM and they have been excellent. I use them to strip as well. Great value.Southwire ratcheting cable cutters. Or Klein’s version for 3x the cost. I use the **** out of these on 4/0 wire and some “entrance” 200 Amp aluminum.
I even use them as a wire stripper by clicking one click at a time and rotating it like a pipe cutter. My wire is marine grade and is tin coated and has extra thick insulation…so the Klein 4 in 1 stripper won’t work.
Thanks for the report!well, after dozen cuts with each pair, for cutting new 2/0 soft copper battery cable the Doyle is the winner, and its not even close. It takes so little effort compared to most of the others.
Might pick up a set later todayThose knipex look nice, but i usually dont want some that large / bulky. Still recommend the doyle. They are the best out of the ones i tested.
I have the Snap-On Blue-point ones and they work great for me.
The doyle cut clean and take the least effort to cut the cable.
