Best budget dial indicator
Ohmthis
Outside of Louisville KY
One of my crappy indicators locked up. I’ve searched for a used mitutoyo indicators on MP near me with no hits. I don’t mind buying used off of the evil bay, but I can’t put my hands on one like MP. I’ve got a few starrett tools, but mostly Fowler. Before I look at something else, give me a good (I’m not a machinist, using these mainly for engine building and small lathe work) budget friendly option. Thanks!
682bear
West GA
Are you looking for a travel indicator or a test indicator?
Teclock is a very good travel indicator, I think they run about $60 new.
For a test indicator, Tesa, Compac, Interapid, Mitutoyo... for a less expensive indicator, I've had decent luck with Fowler and Peacock.
I have a couple dozen indicators of both types... let me know what you are looking for and I'll see what I have if you want to buy a used one.
-Bear
O
Ohmthis
Thanks for the quick reply! Travel is what I’m looking for. Look for TDC of an engine, rear end gearing (my next project), or simple depth cuts on the lathe are my main purposes right now.
682bear
West GA
Ok... I'd recommend trying to find the best price on a new Teclock... I've used them almost exclusively in my 35 years as a machinist.
I still have... and use... the first one I bought back around 1995... it lives on a magnetic base on my South Bend lathe.
-Bear
RoninB4
Under My House
-Just a word of caution. Used measuring instruments can be a good purchase only if they're in good working condition. With dial indicators the working condition is less obvious due to the mechanism being enclosed. The travel can drag/stick, the gear segment or rack can get a minute amount of crud in the teeth, damage to the delicate watch movement can easily occur. All, and more, can contribute to false readings that you'll never know about until after the error happens if you notice it at all. Many of the inexpensive indicators use plastic gearing that is susceptible to wear which can throw off a reading in a used indicator. Lubing an indicator often clears up minor problems with sticking. Testing an indicator is a fairly simple affair too but that's usually not possible at point of purchase and a lot of people don't even have the means to test an indicator at home. For most of the members here I'd suggest avoiding the potential disappointment by purchasing a new indicator.
-Buying new indicators can be on the expensive side so a lot of the decision will be about your age, use, and the expected lifespan of that indicator. Also, how accurate (not the same as precision) do you need to be? There's a whole lot of difference between .003 and .0003. One of my first indicators was a Federal that read in increments of .0001, it was inappropriate for milling operations. Another aspect is expected range of travel and how large can it be before it's too clumsy to work with.
-I can't offer much in the way of brand recommendation because I haven't purchased an indicator in several years and budget friendly brands are not acceptable in some types of work. Most, if not all, of the inexpensive indicators are from China and can be sorta ok for garage work but I would be very careful about the work environment, even a tiny amount of crud can/will foul an indicator. Rough handling is also a death sentence for many inexpensive brands. Repair of inexpensive indicators will also be up to the owner, many professionals refuse to work on instruments they feel are not worth the repair cost and part replacement is often nonexistent. This makes a great many of the less expensive brands a disposable instrument.
-There's plenty more I could say about indicators but a lot of it is opinionated by my personal preferences and experience. Some informative reading about brand comparison can be had at the link below.
m.d.hunter63@hotmail.
I'll echo what previous posters have stated, cheap imported DI and DTIs may work great for a while but, unless the hands fall off, you generally don't know when they go bad.
I like Federal because of the metal plunger cap.
Brown & Sharpe is another good one
Compact, B&S, Interapid I believe are all made by Tesa.
Look on eBay, find one still in the box,or take 682 Bear up on his offer
Rusted Nut
Northern Arizona
Check out Fowler Precision. I’ve been very happy with their value line of measurement devices, really good value IMO.
William Payne
Wanganui, New Zealand
How much are you wanting to spend? Mitutoyo is not that expensive. Insize isn’t bad They meet calibration much the same as any other brand. Which is really what matters. Everyone commonly buy Mitutoyo due to them being industry standard. They are the Toyota of measuring tools. Not the cheapest, not the most expensive, but they do exactly what they are supposed to do.
strutaeng
Dallas, TX
I've had good luck with HF dial indicators for general work such as engine thrust endplay clearance check, deck clearance checks, auto transmissions clutchpack clearances, axle ring gear backlash, and other general uses.
