Best Demolition Screwdrivers?
oldschoolcraft
Bay Area, California
I currently own only one set of demolition screwdrivers. Wiha that came in a 5 pack. The slotted are models 5533 and 5534. I hadn’t had a chance to abuse them much. I need some more for various kits.
I like Milwaukee in general but their demo screwdriver has bad reviews on Amazon. The top picture shows a broken one.
I’m aware of Klein 602-7DD and 602-4DD for 4” and 7” versions. I like Klein stuff usually but no experience with these.
What do you guys like?
tamaraw
Aren’t there tools for demolition better than a screwdriver?
Vessel makes fantastic drivers, I’m just curious exactly how one would use them for demolition work vs say a Recip saw.
A sawzall would be used for cutting things... a screwdriver would be used for prying or poking.
It doesn't mean demolition as in "I'm going to destroy this building using nothing but a screwdriver", it just means that it is a heavier duty screwdriver. For example, something that you could smack with a hammer to shock a seized fastener. Or something that you could also use as a light duty chisel or pry tool.
dscheidt
Yes, but it depends on what you're doing, and most of the time you're doing demo, you don't have a zillion tools. you generally want a screwdriver or two, so why not have drivers that do double or triple duty as a punche, or a chisel, marshmallow roaster, or prybar? It's demo, not precision electronics repair, so beating on stuff is normal. Yeah, you're going to wear your screwrivers out, but the good demo ones take a lot. And they're consumables, they save time and effort, so replace them when needed.
T45
If you are doing contractor stuff around the house, maybe look at klein. Alot of variables come into play with thin kind of work, not just durability, but also functionality as a screwdriver, how heavey/light, how it fits in your tool bag/belt/pack, etc.
On the go, working out of a soft bag, I personally value drivers with more compact handles.
That being said, for actual demo or prying work, there are some pretty good tools out there. 20 years ago, snap-on seemed to make the ONLY tang-thru prybars. Now, these are widely available everywhere, even HF and HD and Husky, Milwaukee, etc
The more recent "evolutions" if impacting pry bars...include some that look alot more like screwdrivers. Worth mentioning, IMHO.
10in tang-thru, straight shaft, prybar
Mini size, straight shaft prybar
Madjik Man
dukefx
I usually recommend the best (best fit and durability) screwdrivers but in this case I'd consider them to be consumables and a bang for buck option might be better. Something made in Taiwan like Toptul or Teng Tools. They both have tang-thru, should be realitively durable and dirt cheap. Alternatively the yellow Weras if you want to spend a bit more for more or less the same quality.
F-22
Surprised noone mentioned these.
The Vessel Power Grip. These are really beefy tools. The small 5.5x75 is the one I always carry with me, so much strength in such a small screwdriver.... Ideal for prying stuff but works great as a screwdriver.
I ordered mine on Japanese Amazon, and if I recall they were more around 8€/screwdriver. The prices on US amazon are overblown. The shipping from Japan is really fast and I haven't had a bad experience with the Japanese amazon but did with the US one (reselling used items or totally wrong items).
tamaraw
Can you please share the model name or number? I can’t find them on their website.
Bubba Fett
Eastern NC
I have the Mayhew dominator screwdriver-style prybar. I like it.
I also have demo drivers from Irwin and DeWalt, which both have 5/16" Keystone, and #2 Phillips drivers. I mainly use the Keystone driver for prying wiremold from the wall, temporarily pulling trim away, or general poking and prodding. The Phillips driver gets used for screws that have been painted over. A good tap will push it right through the paint, and firmly seat it. I usually use the other driver as the mallet.
Keep you expectations in check. These tools are not indestructible, and they are not pry bars, or chisels. They can be used as such, but they really don't work as well as the proper tool. In fact I'd say the entire concept is a bit gimmicky, but tool manufacturers basically concluded that since these tools will get mis-used, they may as well make drivers that can handle the abuse.
I would NOT use these for electrical work , since the through-shanks and endcap can conduct electricity.
JradM
Alberta
I have heavy duty screwdrivers from Vessel, Wera, Bahco & Felo - but I don't use them as demolition screwdrivers, even if they would perfectly fit that role.
Instead, I use Irwin's demolition screwdrivers. They're surprisingly good, heavy duty and robust. Nice enough actually, that I still feel bad abusing them, even though they weren't expensive and that's precisely why I bought them.
There aren't a lot of things I would recommend from Irwin, but I like these screwdrivers. The tips are precise and they just feel tough whether using them to turn a fastener or as an impromptu chisel.
If you want to lean more into "demo" and less into 'screwdriver", then I would instead recommend the Mayhew Dominator pry bar screwdrivers.
Mayhew makes top tier stuff - including items for Snap-on. These are extremely robust, but a little much for screwdrivers. They come in different lengths and straight or curved.
They also have more traditional screwdriver designs, but while I would trust the brand, I haven't tried these:
M635_Guy
NC
I'll have to look into the Dominator stuff - I have their prybars and they're terrific.
Absent that, for ten bucks I'd probably grab the Doyle Demolition set at HF. I bought a set of the Doyle Heavy Duty screwdrivers for my spawn's first-apartment kit, and was pretty impressed with them for the $$ - instantly made me regret the Milwaukee set I'd grabbed as a beater set that was more expensive even on sale, and not very confidence-inspiring (though they've been fine so far).
lardy1
The Mayhews are a great tool. I'm not sure how well they work as screwdrivers but they do the things I don't do to my good flat screwdrivers.
tamaraw
Correct, or for poking holes in drywall.
Side note that there are models with a ceramic ball that isolates the blade from the striking cap. More of a specialty item, but here are two examples:
njride
Glad to know about the kleins, I use My regular kleins in live panels, but using one of those would be interesting lol,with the shank being all the way through. Anyway the second Pic in the listing they show it being used on a breaker in a panel. I'm surprised klein makes them honestly, that's gonna catch some old electrician with a big surprise.
WWheeler
Middleofnowhere USA
TIL all screwdrivers are apparently not demolition screwdrivers. ¯\_(ツ)_/¯
bigredcornhead
This is the exact reason i go to garage sales, i will buy every square stock steel old craftsman or other brand standard. So i can beat the **** out of them. Right now i have a Sparta brand square stock that takes the abuse lol
Pinemarten
Washington
Key word.............Demo...........use some crappy yard sale, road found, or chipped/arc burnt screwdriver you are good pounding on with a BFH. Get a crow bar with the money you saved!
NoahG
Detroit, MI
Honestly Ive always been happy using the cheapest ones from the dump bin at the bottom of the screwdriver rack from Home Depot.
Bubba Fett
Eastern NC
Lowe's has Toughbuilt demolition drivers that I suspect are made by the same company that makes Milaukee's. It's not really a screwdriver, but has more of a chisel edge and a notch that might be good for pulling nails or staples.
Item #5081536 Model #TB-H5-D-X
danski0224
Near Naperville, IL
The Menards ones ****, sold as a 2 pack, straight and cross tips.
The handle is somehow not attached to the through shaft, and it will loosen and spin.
I generally like Menards stuff, but this one is a miss.
ShiroCarpentry
The broken Amazon ones are probably fakes remember Milwaukee has NO AUTHORIZED retailer on amazon everything from them on amazon is either resells or fakes this information is from Protoolreviews.com
M635_Guy
NC
I’ll play...
Herbrand for anyone wondering.
I didn't get anything in a quick search, but thing is srs. If I was doing a lot of tough demo I'd have one of those...
The Doyle demo (flat head) has a home on the side of my bench
