dlcwent
Member Emeritus
I thought I should add that cutting oil goes along way also when drilling and keeping the bits sharp longer.
I usually only buy drills as single myself... it's the drill BITS that I buy as a set.
I like Norseman for metal myself
I have drilled many thousands of holes from small to really big, in mild steel and tool steels, and like others have said, the quality of the drill is only one part of the story. The drill has to suit the material being drilled and then you have to make sure cutting speed is correct as well as cutting feed (how hard you push). Oil is good for some light drilling but you really need cutting fluid. It is typically mixed (emulsified) with water and adds a cooling effect. Oil has very low heat conductivity and doesn't pull the heat away very well.
When drilling holes in steel, unless you have a really powerful drill press with feed, always start with a pilot hole for anything larger than about 5/16" (hand drill) or 1/2" drill press. You will be amazed at how quickly you can put a hole through a piece of steel plate. The trick with the pilot drill is that it has to be about the same size as the web of the drill for the final hole. For hand drilling, I will sometimes step up the sizes. Start with a 1/8" or smaller if you can manage it without breaking it and go up from there.
The death of a lot of drills is that they spend too much time rubbing and not cutting. You would be blown away if you saw how fast a drill can go through a piece of steel with the correct cutting speed, feed and coolant. And it will last a long time.
Is it possible for one set of quality bits to last a lifetime ?
... I have drilled all sort of metal from gummy aluminum to Inconel, Titanium, and anything in between.
Yes. But it depends. In the toolshop that I worked in, you eventually have sharpened the drill so many times that it is too short and the web gets too thick. As an enthusiast at home, a good set should last a lifetime. There is a lot of skill required to do that though. All the stuff mentioned above will make it last. I have an SKF set that is about 30 years old IIRC.
What deems a bit garbage is either total failure (broken) or worn out at the margins. Once it wears out, it acts like a tapered plug gauge where the tip is smaller diameter compared to the rest of the length. You will then risk breaking it off and it will heat up a lot and burn out.
So what kind of drill bit do you use on Inconel and/or Titanium ?
Would you recommend a drill doctor or manual sharpening on a grinding wheel?
If anyone is interested in Norseman drill sets or any Norseman products for that matter, I will be posting the details for the group buy in the Hot Deals section later today.
