Best File Handle?
JonesRestorationCo
What file handle do you use? I personally like a plastic or wood handle. Not a big fan of golfballs or corncobs. Share yours!
Dave455
Sussex, England
Best option seems to be to get files with handles pre fitted. They never seem to come loose. Unfortunately, the handles always seem to be “minimum acceptable” quality, even on the decent files.
I hate the screw on handles. They always seem to come loose.
Best ”aftermarket” option seems to be a decent wooden handle (the “Python” handles shown below seem to be better than most) or a good quality hard plastic handle. The PB Swiss are CAB, so very durable, and come in different colours so you can quickly find the grade of file you need!EC0A2207-7C26-425A-80F8-19D9EB025DBA.jpeg
Fatboy148
I don't know if they are the best but for me these wood handles were a good compromise between quality and price. I liked them a lot more than the Nicholson offerings that I tried and they were about half the price. You do have to drill the wood to fit the file you want it to go on and I found with most of them, I could use the next size larger handle than they list them to be used on. I have dozens of them. Having said all that, DO NOT try to purchase the Mercer plastic handle version they offer in the listing as it will not be the number they appear to advertise, you will get.... one handle and inserts!
https://www.amazon.com/dp/B01MYBH12Y/?tag=atomicindus08-20
Bubba Fett
Eastern NC
I like those as well. Quite comfy, and you can stain/urethane/paint them if you want.
FMB4
I like the wood with steel ferule 'knock on' types. The plastic molded on to the file is good for me as well. Then there are the wood with spring wire wrapped ferule types that work very well. I don't see these much anymore tho.
marak
Anchorage, Alaska
I chose to make my own file handles out of old broom handles and misc. dowels that I had lying around and out of old driver handles and paint brush handles, then epoxied them on. Proportioning the handle to the size of file has been beneficial. Have had most of these for over 15 years and have had no problems with function. Now that I have a wood lathe, a profile will be added to future homemade handles. Nothing worse than an old rusty and sweaty tang!
marak
Anchorage, Alaska
Dull files can be rejuvenated by immersing them in a mild acid solution such as acetic acid (vinegar) followed by a dip in a solution of sodium bicarbonate (baking soda). Stronger acids can be used and would require less immersion time...just remember to "do as you otter and always add acid to water". Before immersion in the acid, I clean the files with a file card or something not as hard as the file to dislodge gunk the file card is unable to remove. After immersion in the baking soda solution, which neutralizes the acid, make sure the file is completely dry. For this I often blow it off using an air gun attached to the air compressor. Completely rubbish files I set aside for converting into other useful tools.
Legion Prime
Leelenau County MI
Whatever I can find, I see a cheap handle on Amazon? Add it on, I've got a file for it. Broken shovel handle? Hell yeah I've got files that need handles. I find a branch big enough you're damn right I'll use a chunk of it. I've got more files than I know where to put them let alone what to do with them all.
Does anyone keep their old files? after mine get dull i put them all in a box but i never use a dull file, I always buy new ones.
i send mine to Boggs Tools in Paramount CA to get resharpened. Learned about them from a guy who made tools, he'd send new files there for sharpening before he used them.
I buy old files made by good brands to send there. Some fans say they are much better than new, and I can get oddball shapes that almost no one sells anymore.
lilredex
Toronto
Most of my file handles are DIY projects.
ecotec
I don’t think that it matters that much. Most of mine are Lutz, but there are other brands mixed in and some homemade. I do prefer to have handles on the vast majority of my files. I have a few small handles with collets for needle files.
seber
Deep East Tx.
some years ago when I had a wood lathe I copied my fathers method of making file handles. Turn them on a lathe and use wire for the ferrule. The one in the middle is my dad's version. He used solder to close the ends of the wire. I bent the ends and stuck them into the wood about 3/16". I wish I had made a lot more of them, but at the time, I just didn't have many files and didn't think I needed more. I now have over 50.
kjbenner
NE Ohio
Most of mine are from House Handle. They're kind of roughly made, but the hickory holds up well. I always mount mine by heating up the tang with a torch and hammering the handle on, and have never had problems with it coming loose.
