petalmasher
- Joined
- Aug 13, 2014
- Messages
- 33
Shortly after I got my job I had a bolt head that I couldn't get at with a Ratchet and socket. I ended up going to a nearby Ace and bought a set of 5 GearWrench flex ratcheting combination wrenches. As it happened, I ended up using these wrenches a lot. Having a few of the more commonly used sizes in my tool bag has saved me a lot of time, not needing to open up my socket set find the socket/extension/ratchet and assemble them. They have saved me some trips back out to my car to get my pass-through socket set. Plus, there are the occasions when only these wrenches would give me access to a nut or bolt.
After a year of use, the rings occasionally start to slide out of the two sizes I use most as I’m using them. I can pop it back in, but I feel like I’ll eventually end up having a spring or some other component fall out from inside the wrench when the ring slips out, so I am looking to replace them. I am not into warranty replacements because if the way and frequency with which I use a tool causes it to break or ware out, I don’t need another one to replace it, I need a better one that can stand up to my use. Particularly since the same thing is happening with two of them, it seems they are just aren't up to the task as opposed to being a freak manufacturing defect that wouldn't be likely to happen again.
I know that ratcheting wrenches are kind of Gearwrench’s wheelhouse, but I’d like to know if anyone knows if there is a company that does it better. I’m looking at these: http://www.amazon.com/gp/product/B001HWOQAK/?tag=atomicindus08-20, I’d like to hear if anyone has experience that sets apart a particular brand as clearly better than others.
