I'll add a side note...
Whichever building you decide to build, recognize that the doors are often one of the weakest links on the building.
Obviously, if the doors are open (and facing the wind), wind resistance goes out the window. But even if the doors are closed, wind can be an issue. Rollup doors are one thing, but many pole buildings have large sliding doors. Here's the benefit of my experience with the sliders:
If the wind is blowing directly at the doors, you need to make sure you have a very sturdy bottom center post that the doors securely attach to. It also works well to have a concrete 'step', about 1" high, running the length of the doors that backs them up (so when the wind blows, it blows them back into the concrete, instead of putting all of the tension on the center post).
If the wind is blowing across the doors (laterally), then securing the outside edges of the doors is critical. Make sure you have a sturdy, mechanical link that ties the two doors together in the middle (when closed) and a secure mechanism to hold the outside edges of the doors tight to the building (again, when closed). Do not rely on the tracks to do all of the work! If possible, spec top and bottom tracks (instead of top only). And KEEP THE DOORS SECURELY LATCHED WHEN NOT OPEN!
