Best household battery tester
Poe34
Can anyone recommend a decent household battery tester? After reading reviews on Amazon, it looks like most testers do not test the battery with a load and reads all batteries as "good."
torqueman2002
I have an older model similar to this --> Midtronics PBT200 Battery Tester with Charging System Test. It tests the capacitance of a battery, and ability to accept and hold a charge.
It is best used in conjunction with a load tester, like Clore Automotive Solar 1874 500 Amp Carbon Pile Battery Load Tester.
Wait, did you mean household batteries? Like AA, AAA, C, D, 9V?
Eric29
Western NY
Interesting. I was talking about the one from ZTS though because I thought the question was about batteries found around the house. ZTS has some less expensive testers that do not test as wide a variety of batteries but they do test them under load. I do not think that the inexpensive testers test under load. I think the inexpensive testers are voltage testers. I don’t think that for $7 you’re going to get the circuitry to test a battery under load.
Strangely there are 2 different MBT-1 testers...one for dry cells and one for 12v auto style wet-cells....
https://www.amazon.com/dp/B000FQG1XE/?tag=atomicindus08-20
https://www.specialized.net/pulsete...YJFPCCIA_UH5ZkXaHcPliotC7a6ho7_EaAsYhEALw_wcB
MaximRecoil
Maine, USA
I've yet to see a battery tester of any kind that was any good. The best test is to just use the battery and see how well it works.
A couple years ago I had a cheap Walmart "ValuePower" battery tested at my local Advance Auto. They had a fancy computerized tester which printed out the results on paper, which I assume was all kinds of expensive, and it reported that my battery had a dead cell. I took out my multimeter and showed the kid that the voltage was 12.6, and asked him to explain how it's possible for a battery with a dead cell to have a voltage higher than ~10.5 (a 12v car battery has 6 cells in series, ~2.1 volts each). He had no answer. I'm still using the battery today and it's fine.
I've used professional battery testers like the old Snap-on YA201 and had batteries that tested good (including on the load test) yet they could barely crank an engine.
Davefr
OR
Sometimes there's beauty in simplicity. This is the best one I've ever used for 1.5 V batteries.
You could also try WC Fields's nose but an LED doesn't put enough load on a battery compared to an fillament bulb.
My tongue does a decent job on 9 V batteries. (no image)
richfinn
Leeds, Yorkshire, England
Vehicle batteries I like to use the amp clamp method to see if they will absorb current when discharged (this is partially what a midtronics unit does if it comes with a clamp)
Small batteries out of keyfobs and watches etc. I like to use a regular multimeter set to D.C. volts and then apply a load with my loadpro test leads
mfewtrail
The old "free" HF meters which I don't believe are free anymore have a battery test function that puts a small load on them.
TuxThePenguin
I literally linked the datasheet shows that it is testing under load.
If you don't want the $7 tester, that's totally fine.
But it does test under load.
Do you want to test under a higher load than 4 ohms (which at 1.5v means 375mA and about half a watt or so)? I can see how you might want to do that with C and D cells. I think 375mA should be reasonable for testing AA and AAA at least.
The ZTS might fill a gap between the cheap testers and the expensive battery capacity testing stuff (or electronic load) though.
SeisMec
Beryl, Utah
If you're asking about an automotive/motorcycle/riding mower/... battery tester, I am very happy with my ANCEL BA101 (for 12v lead acid batteries rated 100 - 2000 CCA). I've had it about a year and a half now. ANCEL also makes a $10 cheaper BST200 (for 12v lead acid batteries rated 100 - 1100 CCA).
BlakeTheCarGuy
Roanoke Virginia
I don’t know of any modern ones I use my dads Diehard from Sears it is a tester and charger he bought it new in 1983 never had any issues with it
Eric29
Western NY
I own that tester. It doesn’t give accurate readings on batteries and I don’t believe the data sheet.
Or perhaps it’s more accurate to say that I don’t care what the data sheet says. The tester doesn’t work.
