Best Landscape Fabric?
D45
NW INDIANA
Doing some landscaping around my deck and pool shortly
What's a good weed preventing fabric / underlayment?
glentre
Gloucester, Virginia
In my experience, no landscaping fabric works well. After the first year or so if you're putting gravel or stone over it, enough airborne dirt and dust accumulates on the fabric for weeds to get a foothold. I've found that a 2" base of coarse stone with your pea or decorative finer size gravel over the base works better for both drainage and weed control. Probably because the stone layer is too thick for accumulation of dirt and no sunlight gets through the stone for the weeds to grow.
I've laid fabric in planting beds and cut holes in it to plant bushes and shrubbery but weeds just love growing in the thin layer of mulch or soil covering the fabric.
Glen
rockcrawler
Dallas, TX
Skip the cheap plastic stuff the the big box stores sell. Use the woven fabric stuff you get at specialty landscape accessory providers.
like2wheel
On an as needed basis
I’ve had bad luck with the woven fabric, weeds grow and their roots make their way through the fabric and they were very tough to pull.
So last time I used regular six mill black plastic. 2 to 3 inches of decorative stone over the top. It’s been years and still working great. There is a layer of dirt in the low spots now, but weeds don’t seem to propagate very often, and when they do they are very easy to pull.
rieferman
Collegeville PA (30 min west of Philly)
I use the woven plastic (geotextile) from landscape supply under multiple large gravel patios on our property. One is 20' x 20' and the other is twice as big.
In my case, I use this to keep the mud underneath from mixing with the patio gravel (red chip 3/8").
Of course, debris will enter from above and eventually weeds do occur... but after 10 years, we are still nicely separated from the mud (goal #1 in our case) and the weeds have so little material to root in that pulling or spraying makes quick work of them. I spend about 30 minutes per year handling the weeds in these two large patios.
Now, for a flower bed that will presumably have mulch (instead of gravel) I think you'll just end up growing weeds anyways, so I use Preen type product there, along with spot spraying and good ol' fashioned pulling weeds once in awhile. I spend about 2 hours a year on these tasks.
tthornto
FYI Sams club has a 250' roll of the good woven stuff for about $30 right now (and usually every spring). Best price I've found. I agree it's useless if putting mulch over it but for under stone it works good. I picked some up for around an above ground pool, going to top it with river rock.
Bretny
Dutchess county NY
i used this stuff for a french drain i put in, not cheap but this stuff is thick.
Your right that stuff isnt cheap but that dosnt make it good.
If you want to keep the gravel separate from the dirt/mud under it then "road fabric" is what you should use. For keeping weeds out nothing really works becids a deep base of stone.
I was building a driveway and called around to many local landscaping and drainage supply houses. Generally road fabric is $1 a linear foot of 12ft wide. It's well worth the money.
mike93lx
Richmond, VA
The fabric stops the stone from mixing into the dirt, but won't stop weeds from eventually growing. Use something permeable
D
D45
NW INDIANA
I have all the old river rock removed and I scored 470 used brick pavers for the edging
For $150 and a few hours of power washing they look new
I was told to use thick plastic mil sheathing for the river rock underlayment
Anyone else use plastic? Where does the water go?
like2wheel
See post #7.
I just poked a few holes in the low spots.
Just remembered I did that under the stone around my hot tub too. Been almost 10 years still holding up well.
L5wolvesf
Northern AZ
We have thick plastic sheeting under just about everything. It is at least 15 yo and probably over 20. Weeds eventually poke through as does gravel. so water drains down or away. When I have to dig I pull up and toss as much plastic as possible.
rayra
Escaped from Los Angeles
+n. Not sure the word 'best' applies to the product category. If not covered, it breaks down / falls apart, if covered too well, stuff grows in the cover. And I've never seen a brick&mortar store that had a selection to pick from.
eta at best use black plastic to cook / kill any weed seed / sprouts, before your planting, then mulch. Removing the plastic.
like2wheel
Disagree.
I've got some 6 mil black thats been exposed to the sun for YEARS that is still fine. Prob at least 10 years so far.
The clear does break down after a year or two.
Don't understand your comment about being covered too well. Remember he's using stone.
D
D45
NW INDIANA
Seems like 6 mil is the best
Some say 4 mil is too thin
One layer of 6 mil should suffice? I want to do this once and not have to worry about it for a long time
D
D45
NW INDIANA
Rock is all removed ......wasn't too too bad
Shopping for some plastic rolls this week
D
D45
NW INDIANA
Project is done
New double row brick edging put down, with the plastic edging support rolls installed (great prices at Menards)
Plastic installed with nice plastic button cap staples and 6.25 tons of new river rock
Total cost was around $750 and a week of work
Better than the 5k quotes
CSRPenFab
Meridian Idaho
+1 for the commercial quality stuff from Sam's Club. At my prior CA house, I had a few thousand sq. ft. of it down under rock and bark in all the planters. It worked quite well. Even if weeds came up, it made removal very easy since the roots never got a firm grip in the soil.
Now at my house in Boise, the builder used that really heavy woven geotextile stuff under gravel all around the yard. It too seems to work very well, and the few weeds that do get through are very easy to remove.
