Best "liquid steel" epoxy, polymer, etc??
MatBirch
Filer, Idaho
I need a good one, and have never been too happy with the results of JB Weld. What are your experiences?
FWIW-
This will be hopefully extending the life of damaged splined shaft w/ sprocket. The shaft is very expensive, labor is very intensive, and downtime is a killer...
I can weld the sprocket on, and have seen it done with some success, but I'd rather try this first, as there is no return once I weld.
Thanks!!
rlitman
Long Island
Belzona makes a number of products. They are the best in the business!
Not everything of theirs is super expensive. They make stuff in single-use size packs too.
BearsFan315
Portsmouth, VA
so are you using the "liquid steel" to reshape the splines ?? or as a glue to hold the sprocket on ??
as for belzona we use that to repair castings and machined parts all the time here. and you can machine it if required. we do this all the time to build up a surface.
Radix2
the thumb!, MI
Can you say a bit more about what type of castings, material, temperatures, etc. that you use this for?
LXCam
Good luck. I sure don't know of any resins that could handle the torsional load of a gear.
EOC_Jason
Bentonville, AR
marineengineer
Vermont
At work we have used devcon but have moved to a ceramic composite product call encon. Purchasing likes it because its cheaper but i like the much longer shelf life and use-ability it offers in the shop. Pretty simple to use and they have all different kinda of repair products and i wouldnt hesitate to use any of them the hardest part i jave had is choosing which one to use in which application.
http://www.enecon.com/products/
PWC Repair
Arkansas
I made a cone once with a cut up soda can. Place over the splines and tap the sprocket on home. Tightens everything up nicely.
MatBirch
Filer, Idaho
Care to elaborate? you ultimately just smashed the thin aluminum between the sprocket and shaft? galvanic corrosion?
I like the idea! especially if I can use a beer can!
PWC Repair
Arkansas
Yep, smashed the aluminum in between the parts. If I remember correctly I was trying to get a cement mixer into working order. I might have even only wrapped the can piece halfway around cause of how tight it got, been years ago.
matt_i
The fact that the splines are usually case hardened means to me any epoxy substance put in there is going to come out as dust or sand in short order. I respect the epoxy but this is not a place it has a chance, if its loaded like I think in my mind. If anything I'd use carbon steel shim stock. Start with .010".
