Best Machine Tool Cleaner?
Southernbuild
North MS
I've got a couple of machine tools that have been in deep (less than ideal) storage, plus I'm acquiring some new (to me) grungy machines soon, and so I was wondering what the best cleaner for the job is?
A combination of dirt / grime, rust, oil, and grease....
Last time I did a similar job, I mainly used bulk WD-40, dispensed with a sureshot sprayer. Just checking to see if there's better options, CRC has some cleaners that look good, but the cost gives me pause, with the volume I'll be needing. Enclosed space in the winter, so I'd rather not have the fumes of something like brake cleaner....
I'm not planning to repaint, or restore at this point, just want the stop the damage, and get them usable.
seber
Deep East Tx.
Simple Green but be sure you wipe with an oily rag after. In fact you should do that no matter what you use.
LJZ
Rochester NY
Your query made me reflect back a bunch of years.
We use to stop a half hour early every Friday to do a General clean up of the shop.
We used the crappy old stinky soluable oil, cool tool, standard at time cutting oil, anchor lube, Tap free (the old stuff that worked) and other stuff. the machine's would get pretty yukky.
We used spray nine to clean the gungula of and it worked fantastic. We also had Doall cleaner that worked well but it would attack repainted machines.
Has it been made Al Gore friendly now? I dunno. Saw some at Lowes few months ago by chance and almost got some.
As mentioned Simple Green is great stuff but be careful. They make an aviation simple green thats supposed to be Al lou minny yum safe.
Haven't tried yet myself.
So just to say FYI FWIW.
good luck
Luke
rustyzman
Chicagoland
We degreased machines with soluble machine cutting oil. Trim Sol and later a local company blend. It was very good at removing most greases and maintained some corrosion protection afterward even though it was a water soluble oil.
American Locomotive
Rhode Island
The best we ever used at the machine shop I worked at was CRC Citrus Degreaser. Cleaned well, evaporated cleanly, and wouldn't cause rust since it's not water based.
It is pricey though, and comes in two versions. CRC Citrus Degreaser, and CRC Citrus Degreaser MUO (Manufacturing Use Only).
The MUO version works better if you can get your hands on it.
IndyGarage
Indy
I've used Zepp Fast 505 on Machines with pretty good luck.
That and/or greased lightning.
5 gallon bucket with a big scrub brush and a rag. Blow it off with air or a leaf blower afterward then spray down the important parts with WD40
Willie Makeit
been in and around the machine tool business longer than I care to admit and was taught a very young age to NEVER use water or water-based cleaners around machinery. have always used WD40 or kerosene for cleaning, even new machines that are shipped from across the pond covered in cosmoline are cleaned with WD40.
dr_clyde
Holland, MI
I use simple green for most lighter duty stuff and purple power for the heavier duty.
Depending on the machine and the severity of grime I’ve also been known to use a hot water pressure washer.
