Best method for cutting metal on this project?
BlackdogGS
The Dalles Oregon, Puget Island Washington
I finally found some rocket stove plans online that I’m happy with. Basically you glue the pattern on your material and cut it out. I have a plasma cutter that would normally make short work of this but the heat would burn the paper. I got these plans from a YouTuber and he shows how he cut them out using a jig saw. The metal is 3/16” and my saw with new blades won’t hardly scratch it. His video shows him buzzing through it like it was wood. I ended up using a cut-off wheel and it took about 3-4 hours and now I have another 3-4 hours of grinding to do. Is there a saw blade that can actually cut 3/16” metal?
gearhead1
NC
Look at an Evolution saw. They have hand held and chop saw versions.
tarbellb
Oregon
Well his video is sped up, but with the correct speed and blade a jig saw can cut 3/16". ie down stroke cut action with 18-22tpi
Havent listened to or studied the video, but 3/16" wall seems very heavy for this application? Why so heavy of wall?
LXCam
Well first off that sure looks like .120 wall tubing. But even at that it takes time with a jigsaw. So dont go losing sleep over that vid.
Past that you could always use a straight edge and the plasma for the majority of the cut then use the jigsaw for detail work.
BlackdogGS
If I could somehow transfer the pattern directly to the metal, maybe one of those etching tools? I was planning on making 2 of these, I have 1 cut out so far and need to finish grinding it. I’m glad I’m not making more then 2.
fordkid88
Cut off wheel. It's not a machine tolerance project, rip into it and hit it with a flap disc afterwords and call it a day.
csp
Franktown, CO
Mark the steel with a sharpie and then a scratch awl using a steel rule to keep the lines straight. Remove the pattern at that point.
Then cut it with a cut off wheel on an angle grinder on the scribed lines and you should have minimal grinding to clean it up.
Tubing is not difficult to cut cleanly with a cut off wheel.
Merch1
Waaay back when I was an apprentice, we were shown how to use a centre punch and follow the cut lines. Punch right on the pattern. Remove the paper and cut following the punch marks. The theory being that if you cut half of each punch mark off you would be following the line exactly. Still use this method sometimes.
