bmxr4life87
Highlanders arent that bad. I hate doing is300 and gs300 filters you gotta take up for slack in the motor mounts with a 2x4 jammed between intake plenum and inner fender
There one of those proto filter wrenches on ebay now !
I don't understand why people don't just use channel locks. I use the big ones and find they work better than any special wrench I have ever used.
I can't get a channel lock on any of my oil filters. They are blocked by frame on all my rigs.
I use my hand 99% of the time.
My Jeep has a cartridge up top and that is super nice. So easy.
My F350's 7.3 diesel is a giant filter on an angle that is hell bent on making a mess. I judge the success of my oil changes by how little I get on the floor.
All rigs except my F350 are 100% clean floor. . .the friggen Ford is hit and miss.
Hey Mom, meet my girlfriend??
As mentioned in post #19 it's a Proto 2304 (no other markings). I bought it about 35 years ago, most likely at an automotive jobber (parts store) that we dealt with back then. I have no idea if they are still available.This one here, by Proto, looks like it would be an excellent one!
What is the exact model/part number of it?
Where did you get it at?
Is it even still available?
I've had this Proto 2304 for at least 35 years and it's always worked well.
Apologize for the rant:
Dear Mr./Ms. Japanese Automotive Engineer,
I hope you are sleeping good at night in your cozy bed somewhere in Japan, because I want you to know I am cursing the day you designed the oil filter can in the worst possible place under the hood of the 2007 Highlander.
What in heck were you thinking that day? Did you have some kind of bad argument with your spouse?, did your neighbor yell at you?, did your kids throw up on your oriental rug or worse yet did your Mother-in-law come for a six month visit? I want to know just what you were thinking that very day at your drawing board?
Because I must tell you it just ***** trying to get your arm contorted giving your hand about .0001 inch of room to move let alone fooling around with any special tools.
I only hope that one day you have to change your car oil outside in the snow and your hand gets stuck and you are dying to use the bathroom
Sincerely,
Woody
I've had this Plews 70-715 for almost that long, too. Looks like a similar tool. Works well.
The patent dates from 1985. Here's the original data:
I agree! Nice post 4xdog. Not suggesting you do more work but if you're interested the U.S.A. patent on my PROTO is 3119290. It sure looks a lot like the PLEWS and I'm sure it works just as well.... BTW, impressive post, with the patent documentation, and all...![]()
With all due respect, it's not so neat, at least not on the German cars (Mercedes, Audi)
You unscrew the Plastic housing using a 36mm socket and ratchet handle, pull up the cover with the dripping filter (catching the drips with a rag) put the dripping mess on the bench, pull out the old filter with your hands or a rag, deposit it in a container to drain fully, get a pair of needle nose pliers, pull out the old seal in the cover, oil up the new one getting your fingers oily, insert into slot, get pick, pull off old seal from engine oil filter housing, oil new seal and install, slip new filter into cover and seat, screw on cover, get out torque wrench, set to 25Nm, tighten cover, now clean and put away, 1) needle nose pliers, 2) pick, 3) 36mm socket, 4) 1/2-3/4" socket drive adapter, 5) 1/2" drive ratchet, 6) torque wrench, 7) clean up oily mess on bench...........yeah, this is a whole lot easier and neater than a spin on!
Dave
I can't believe nobody has suggested the one I always use:
