Best oil for tool protection
FadedGray
W. Michigan
Looking for recommendation on what you guys use for oil to protect like hammer heads, axe heads, old vintage tool surfaces, etc, etc. thanks.
fordkid88
Atf is what I go for, plus I can mix with acetone for penetrating oil.
Sh40674
Iowa
if i don't need it in large quantities i use CLP (clean, lube, preserve) find it in the gun cleaning section at your local sporting goods store.
Sh40674
Iowa
*protect.. don't know what i was thinking there.. either way, that or some light oil, WD, household 3 in 1, etc..
matt_i
I use LPS2 for mild protection, heavy coat of LPS3 for long-term storage or stuff that's critical.
I have used Kroil as well.
DCarr2
Akron NY
I use whatever liquid is in the quart can labelled "air compressor oil" in my air compressor... and then I have a ton of these little bottles around labelled air tool oil.... so i use those.
Jeepster04
I've never used anything but if I did find the need I would probably use some sort of gun oil. CLP, Rem oil, Ballistol, etc...
Codejack
Chattanooga, TN
I'm looking for something to put on my industrial finish Snap On ratchet; they aren't supposed to be bad, but apparently the Southern humidity is a little much for it.
I've been wiping it down with WD-40, but it only lasts a couple of days.
My next plan was to buy some oilcloth and sew a "sock" for it, like a gun sock.
Lelandwelds
Central Texas
Corrosion X, Corrosion XHD, Break Free CLP, any synthetic motor oil, Sprayon aerisol waxy coating (modern cosmoline), or vapor bags.
Pretty much in that order. Corrosion X even works in salt water. Anything will work. Question should be " How often do you want to apply it?".
DGersic
DeKalb, IL
Gibbs oil. Or whatever is on the rags when I'm done working and start wiping down the tools as I'm cleaning up.
tarmy
Nor Cal
I have used gun socks...they work great...as well as thin or lite gun oil...
Johnny_V
Mentor, Ohio USA
If the tool gets into a wet environment, I'll wipe it down with WD40, but I keep a dehumidifier running all the time. I have a machine shop in my garage and the dehumidifier has kept my tools and machines rust free for years.
EOC_Jason
Bentonville, AR
Overall humidity in your shop is going to be a huge factor. If you can keep the humidity down the you will do all your tools a favor...
For hammers & axes and such, why not use boiled linseed oil? Or even some type of clear urthane coating? I would think that is better long-term protection if they are going to sit around for months at a time unused rather than having to re-oil them every couple weeks.
Eezox is awesome at rust prevention and lubrication and smells good too...
