Yankeefarmer
The last time I used a rotary hammer to install a condensate line through a concrete foundation, it blasted out a chunk of concrete on the exit side, which I repaired with a concrete patching material. This made me think I should drill the hole in from both sides, like you would do with a spade bit in wood. This could be done by first drilling with a small diameter masonry bit to establish the center line of the hole, then enlarging with the needed size rotary hammer bit from both sides. Is this considered the best way to do it? I searched the web, YouTube, and this forum, but the majority of results were just “the best rotary hammer,” or how to insert the bits and hang on.
